Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Custom Chassis Suspension problem
Old 08-26-2008, 08:50 PM   #1
Default Custom Chassis Suspension problem
I have a problem with the suspention on my custom chassis. Wehn it climbs up tall things, the shocks extend all the way and the suspention links are almost vertical. I need YOUR IDEAS BADLY!!!
custom_crawler is offline   Reply With Quote
Old 08-26-2008, 08:52 PM   #2
shorter shocks, limit the shocks.
Crawler Noob is offline   Reply With Quote
Old 08-26-2008, 09:04 PM   #3
i think it would be easier to make the shock tower higher
Old 08-26-2008, 09:48 PM   #4
Limiter straps.
thunder7845 is offline   Reply With Quote
Old 08-26-2008, 11:24 PM   #5
ElChupoCabre's Avatar
Doing this will not solve your issue... with this much travel you will have axle stear... very bad!!!!! you need to add a limiter to the shock such as fuel tubing inside below the piston. Or use a smaller/ shorter shock. Good luck let us know what you came up with....
ElChupoCabre is offline   Reply With Quote
Old 08-27-2008, 12:38 AM   #6
You could also use longer links
badltl510 is offline   Reply With Quote
Old 08-27-2008, 06:37 PM   #7
i will tie a strap to the axle and i cut a staw and put it inside the shock to limit the travel
Thanks Much!!
Old 08-27-2008, 09:17 PM   #8
Thanks Much!!
Use fuel tubing instead of straws.
revoster is offline   Reply With Quote
Old 08-27-2008, 09:19 PM   #9
666
MODERHATER™
666's Avatar
Looks fine to me, run it!
666 is offline   Reply With Quote
Old 08-27-2008, 09:43 PM   #10
FrankyRizzo's Avatar
X2!!!!
Better beakover
FrankyRizzo is offline   Reply With Quote
Old 08-27-2008, 10:07 PM   #11
Who's your Daddy-0!
x3! Go with it man. It will go where no scaler has gone before! And if your going to use the straws, use TGI Fridays straws, there are much stronger!
TattooKenny is offline   Reply With Quote
Old 08-27-2008, 10:56 PM   #12
dezfan's Avatar
Pfffft, the straws from Shakey's ice cream FTW!
dezfan is offline   Reply With Quote
Old 09-06-2008, 09:02 PM   #13
now i am going to be running four-link in the front and leafs in the back
Old 09-07-2008, 02:14 AM   #14
move the top shock mounts forward or angle the shocks to the center of the frame
james22 is offline   Reply With Quote
Old 09-07-2008, 07:34 PM   #15
Does anyone know where to get a quarter-elliptical spring pack? If they are available one could use them as part of a modified 4-link design (as upper or lower links with a rigid mount at both ends) or in a 6-link configuration (with a flexible mount at the axle end, possibly parallel to lower links) the possibilities far exceed what I have written here... Designed properly such a system could be self limiting in travel (but not overly so) and help resist the dreaded body roll/torque twist problem...
KnutKase is offline   Reply With Quote
