07-03-2008, 03:36 PM | #1 |
Quarry Creeper Join Date: May 2008 Location: Ontario
| What is Torque Twist?
New to crawling and my crawler is on it's way. I just wnat to know " what is torque twist?" Is it bad for the truck? please explain or possibly psot a video of it, and how do you fix it? Just wnat to know befor my axial gets here |
07-03-2008, 03:59 PM | #2 |
Newbie Join Date: Dec 2007 Location: Best Nation in North America
good info here, not bad for teh truck, just makes it hard to crawl. torque twist? |
07-03-2008, 04:00 PM | #3 |
Rock Crawler Join Date: May 2007 Location: lacey
Torque twist is caused by the driveshaft trying to spin the axle. If it can't (axle bound up) it will twist the chassis, usually to the left. It can also occur when an axle is very light, like when you are near vertical and all the weight is on the back axle, the front axle will twist and push you over backwards. in order to fight it, proper link geometry is crucial. do a search for Torque Twist and you will find all kinds of remidies. Best thing to do is to lower the ride hight to around 2.5 in at the skid for the axial, maybe even less, depends on your terrain. Basically the straighter your driveshaft, the less twist. http://www.youtube.com/watch?v=DQcS9CPJ0-s . |
07-03-2008, 05:52 PM | #4 |
ok thatks good to know that it isn't bad for the truck. Thanks for quick replys |
