Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: losi shock question
Old 07-11-2008, 12:25 PM   #1
Moderator Rule Breaker
eric113's Avatar
Default losi shock question
I'm getting some used losi shocks. I like to rebuild them. I was looking on http://www.losipartshouse.com website and saw there, was quite few differnent shock pistons.
Whats the diff between numbers and colors ? what they mean ? which ones should I get ?
eric113 is offline   Reply With Quote
Old 07-11-2008, 12:37 PM   #2
2006 2.2 National Champ
BENDER's Avatar
The different colored pistons have different sized holes in them. I ran the black (#57) pistons for a while with very good luck. The number on the piston packaging is just telling you how big the holes in them are.
Here's a chart that'll tell you what the decimal equivalent is for the numbers on the pistons.
http://bobmay.astronomy.net/misc/drillchart.htm
BENDER is offline   Reply With Quote
Old 07-11-2008, 12:43 PM   #3
eric113's Avatar
Thanks Brad.
Are you running different pistons now ?
Old 07-11-2008, 12:47 PM   #4
BENDER's Avatar
Originally Posted by eric113 View Post
Thanks Brad.
I am running a little different set-up now. My head mechanic (Rubbaneck) recently swapped them out, and I don't remember what we used at the moment.
Old 07-11-2008, 12:51 PM   #5
eric113's Avatar
Ahh I see, I know it hard to keep up with all little stuff like this.
Btw is there any tricks to building them or anything to make them better ?
Sorry for the newb questions, I never mess with losi shocks before... gotta start somewhere.
Old 07-11-2008, 12:55 PM   #6
BENDER's Avatar
They are the easiest shock to build IMO. The only advice I have is grease the seals and install the shock shaft from the snap ring/piston side. If you slide the threaded side through without deburring them, it can tear the seals which will cause them to leak.
Old 07-11-2008, 01:18 PM   #7
Front: 20wt LOSI oil with the blue #54
Rear: Right rear red #56 with 30wt LOSI, left rear black #57 and 35-40wt LOSI
Rubbaneck is offline   Reply With Quote
