Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: msd topgun with rock claws
Old 07-13-2008, 06:03 PM   #1
Default msd topgun with rock claws
is this a good combo? how about the foams. do i need to cut or put holes on the standard foam that comes with the rock claws
thanks guys
aljeann is offline   Reply With Quote
Old 07-14-2008, 08:33 AM   #2
It's a great combo. I've used that exact combo for quite some time now - I use Kreepy red foams in the front with 3 1/2 oz in each and Kreepy pinks in the rear with no added weight. I drill two 3/32 holes in each wheel. You will find everyone does something different - this works for me (took 2nd in state with this) - its a good starting point - change it to suit where & how you drive and the surface you drive on most.
Yawzer is offline   Reply With Quote
