07-18-2008, 12:57 PM | #1 |
Pebble Pounder Join Date: Jun 2008 Location: Federal Way, WA
| Screw or Bolt?
Ok, I am starting the build up of my first scaler. I need to attach two 1/8th inch thick pieces of aluminum together ( like a shock tower to a frame ) I have a drill and tap and was considering tapping one of the pieces and srewing the other to it. Hmmm do you guys think this would be strong enough or should I just drill through both pieces and put a nut on the back. Thoughts? Rob |
07-18-2008, 01:01 PM | #2 |
RCC Addict Join Date: May 2008 Location: On the rocks
nut on the back, just to make sure |
07-18-2008, 04:11 PM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
I agree...and make sure to use thread lock or a nylock nut....
07-18-2008, 04:33 PM | #4 | |
Pebble Pounder Join Date: Dec 2005 Location: Metro NYC
07-18-2008, 05:12 PM | #5 |
Pebble Pounder Join Date: Jul 2008 Location: Lowell
| As I was told, that rule works for steel. With aluminum you want 2x to 3x material thickness for tread engagement. I would think a nut would be far stronger.
07-18-2008, 06:42 PM | #6 |
Thanks for the input. My tap is 6-32, and after reading your thoughts, I think 1/8 inch of aluminum isnt going to be enough thread. Nylock nut it is. If I put all the nuts on the inside of the frame rails and counter sink the screws, it should look pretty clean. Just waiting for a few more boxes from UPS to start the build. ( been playing with my ax10 axles for days and its making me nuts to begin) Rob |
