07-30-2008, 11:25 AM | #1 |
Rock Crawler Join Date: Jul 2008 Location: San Marcos, CA
| tire assembling ?
Newbie, AX10 kit I'm building my tires today, cut the foams (star pattern), next is to add weight, but should I drill a hole in the rims for air to escape? Not sure if the same method for my (T4/1/8 buggy) will work for crawling. Any advice would be cool. Thanks -RCHuffer |
07-30-2008, 11:40 AM | #2 | |
Pebble Pounder Join Date: Dec 2005 Location: Metro NYC
07-30-2008, 12:05 PM | #3 |
Rock Crawler Join Date: Jul 2007 Location: clearfield
some people are running a bigger hole... i am running (2) 1/8" in each of my wheels... it works good for me and my setup... but you just have to experiment... find what you like... |
07-30-2008, 01:50 PM | #4 |
Thanks Guys, for the help. -RCHuffer
07-30-2008, 08:31 PM | #5 |
Rock Stacker Join Date: Feb 2008 Location: Minnesota/Wisconsin
I would start without a hole, and if you dont like it try a 1/16" hole, and then work your way up until you find the size that you like the best the good thing with beadlocks is its fairly easy to change something with your tires/rims because there is no glue to worry about, however you do have to deal with all the tiny screws |
08-01-2008, 11:28 PM | #6 |
Newbie Join Date: Aug 2008 Location: SD
I find that with no holes they bounce too much.
08-02-2008, 01:08 AM | #7 |
RCC Addict Join Date: Jun 2008 Location: Fresno
i have 3, 1/8 inch holes in each wheel its easy enough either cover a hole w/ a little electrical tape from the inside for adjustablility. or use a dab of jb weld to cover a hole for a more permanent fix |
