08-05-2008, 10:46 PM | #1 |
Rock Stacker Join Date: Jun 2008 Location: Eureka
| holmes hobbies motor?
I was wondering about the holmes hobbies motors i keep hearing about. will it fit in my ax10? can i run it off my rooster crawler esc? its good for 12 turns it says? it is brushed i take? let me know what you guys are running. or is there a better motor? im talking wheel speed and torque, which you already know of im sure.
08-05-2008, 10:48 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
His standard 35t and 45t motors are some of the most popular. I plan on getting a 45t from him in the near future.
08-05-2008, 11:01 PM | #3 |
how much torque would his 35 versus 45 have? i have a 55 novak but would like some more wheel speed but not loose torque
08-06-2008, 12:19 AM | #4 |
Rock Crawler Join Date: Dec 2007 Location: GILBERT
i run a 45 and i like it.it can still crawl but on the 8 cell pack i run now it will definatly get up and go. like a wise man once said "volt up and gear down" p.s. three cell lipo on the way=wheel speed! |
08-06-2008, 09:13 AM | #5 | |
The difference between a 55T and 35T may be noticeable but you always want to fine tune with gearing and/or voltage to get the best performance. | |
08-06-2008, 10:59 AM | #6 | |
Quarry Creeper Join Date: May 2007 Location: Seattle
08-06-2008, 06:01 PM | #7 |
I just went from an integy 55t lathe to a handwound 35T. With the same batteries I was pleasantly surprised. Torque actually seems better with the 35T than with the 55T. I did some homebrew bench comparisons, and it appeared that the 35T comes out on top. Of course wheel speed is faster and battery life is shorter, but not as bad as I was expecting. |
08-06-2008, 09:38 PM | #8 |
There have been multiple threads on the issue, the 35T does produce more torque. The only con about a 35T is it will not be as smooth off idle, it requires more voltage to get the armature turning; most people don't notice it, some people do. Side by side a 55T will appear to be "smoother" from 0-1000 RPM. Having a programmable radio helps to put the smoothness back into a 27-45T motor. |
08-06-2008, 09:56 PM | #9 | |
If you want some of your run time back,gear down a little. If you like the speed it has now,get another pack and carry spares to swap out with. You can then run longer without stopping to charge. | |
08-06-2008, 11:22 PM | #10 |
maybe i will be buying the holmes hobbies 45 turn then and give a try?
08-07-2008, 06:48 PM | #11 |
RCC Addict Join Date: May 2008 Location: On the rocks
08-07-2008, 10:57 PM | #12 |
it says 7 turn? will that work with the rooster that is 12 turn limit? if it will i will buy it!
08-08-2008, 12:41 PM | #13 | |
12t limit on a 3 slot motor. Pullers are 7 slot motors. You might be able to run it and be O.K. I'd wanna hear it from John first though. I've never tried it,so I don't wanna tell you wrong. | |
08-08-2008, 10:06 PM | #14 |
| Actually... if you read all the slips of paper in the Rooster box... the new limit on the Rooster is now 27 Turn I think... even though the manual and stuff still says 12.
08-10-2008, 11:47 AM | #15 |
screw it im just gonna go goat brushless then thanks guys
08-12-2008, 01:25 AM | #16 |
Newbie Join Date: Jul 2008 Location: norcal
