08-20-2008, 05:22 PM | #1 |
| Rear D-Shaft on an MFM Widow
I just got the MFM chassis. The tranny mount is way forward and I'm not running a VF dig. I mocked up the MIP rear driveshaft (I don't have the tranny yet) and it looks like it will just barely be long enough sitting flat. Not sure what it will do when flexed. Did anyone build an MFM without the VF or R2? Was the driveshaft length crazy long or am I just not mocking it up right? I mean I have a tranny on another AX so i know how big they are and where the outputs are... etc. It just seems like a really long driveshaft without a tranny mounted dig. |
08-20-2008, 06:43 PM | #2 |
It's not that it's "crazy long"...it's just longer than the front Mine worked fine with a standard length Maxx shaft...and I think I even had to cut it down just a bit. I run full droop, so it may work differently for you if you're running sprung. Your driveshaft really doesn't slip in and out as much as you may think it does on flex. Last edited by Offroader5; 08-20-2008 at 09:04 PM. |
08-20-2008, 07:01 PM | #3 | |
RCC Addict Join Date: Dec 2007 Location: On The Lake
08-20-2008, 07:31 PM | #4 |
Rock Crawler Join Date: May 2008 Location: Mansfield, PA
Get rid of the MIP driveshafts and get some Maxx shafts or Revo shafts.... They are super strong and both are more than long enough and can be shortened to ANY length in a matter of minutes You couldn't even pay me to run metal cvd driveshafts... I change setups far too often to be stuck with a certain length driveshaft. |
08-20-2008, 08:53 PM | #5 |
Wll I was just hoping to use stuff I had laying around for this build... which included an MIP D-Shaft. I'm fresh out of MAXX shafts, but I guess I'll need some anyway for the D-Shaft dig. Thanks!! |
08-20-2008, 09:03 PM | #6 | |
