09-06-2008, 11:14 AM | #1 |
Newbie Join Date: Sep 2008 Location: Atlanta
| Dig Unit
What does a dig unit even do? Would a newbie like me benifit from it if I slap it into my scorpion?
09-06-2008, 02:43 PM | #2 |
Rock Crawler Join Date: Jul 2007 Location: clearfield
not trying to be a RICHARD... but if you use the search button... there is like 10,000 threads on this... maybe not.. that many... but there is alot of the same thing you asked
09-06-2008, 02:54 PM | #3 | |
What does it do???? Several things. Disconnect the power to the rear axle allows front wheel drive only which can help allot in steep vertical climbs. Disconnect with a brake,allows you to turn sharper or manipulate the placement of the front tires. To get full advantage of a dig unit,you'll need wheel speed. | |
09-06-2008, 10:58 PM | #4 |
I saw no need for another thread for this question. Do the stock electronics from the rtr ax10 work in the artr ax10? I plan on getting a different servo and motor, but would the rx,tx, and esc work?
