09-10-2008, 10:28 PM | #1 |
Newbie Join Date: Apr 2008 Location: dedmonton
| quick questions
I'm running axial axles and an R2 tranny, what driveshafts would you recommend? I have coreless digital metal gear servos, would you run a servo saver? can you run 2 servos off of one cc bec? |
09-11-2008, 11:02 AM | #2 |
Rock Crawler Join Date: Aug 2007 Location: Columbia, TN
You can run just about any of the normal driveshafts used for AX10's. Some have to have a little modification but nothing major. Don't know about MIP's but I'm sure they work fine too. As far as the servo saver I personally wouldn't ever run one with this type of stuff. And yes, you can use a CCBEC to power your rx and both servos if you hook it up like the normal wiring diagram shows on the Castle website. |
09-11-2008, 08:30 PM | #3 |
thanks buddy
