10-08-2008, 09:55 PM | #1 |
Pebble Pounder Join Date: May 2007 Location: socal
| woo hoo
I just bought my second crawler which is a red losi mini... need help with what needs to be done with modifications....... thanks
10-08-2008, 11:41 PM | #2 |
RCC Addict Join Date: Apr 2006 Location: On Da' Shelf
Sounds Good! Just read up on all the build threads in the Mini Crawler Section and you will be good to go! |
10-09-2008, 07:21 AM | #3 |
Rock Stacker Join Date: Sep 2005 Location: Ft Knox (but always from Flagstaff AZ)
things i did and will do after i read all of the posts. remove or cut the stock battery tray (i removed mine and mounted the shocks to the chassis), lower electronics (i like the ESC mounted on the rear axel but i have my battery there until saddle packs come out to mount on the front axel. lower body 1/2 inch. remove 1 big spacer from front shocks and add to the rear shocks. get sticky wieghts and mount inside of rim (make sure not to cover the breather holes, i also pulled the tires in the front and mounted weights inside also. i am also going to do the PVC beadlock conversion after i get the blue compound tires. go weight forward and lower the COG and have fun! |
10-09-2008, 07:37 AM | #4 |
Pebble Pounder Join Date: Aug 2008 Location: orlando
well i've removed the battery tray , moving the battery to front links 4 linked the rear bent links front and rear moved esc and rcvr to the trans flipped the trans full size servo 3oz up front 2oz rear extended driveshafts truck is stretched 1" work in progress |
10-09-2008, 07:38 AM | #5 |
and forgot the full size t-maxx shocks, with internal springs (full droop)
10-09-2008, 06:08 PM | #6 |
10-09-2008, 06:28 PM | #7 | |
Rock Crawler Join Date: Nov 2006 Location: Spanish Springs, Nv
| Quote: | |
10-09-2008, 07:09 PM | #8 | |
RCC Addict Join Date: Jun 2008 Location: Fresno
| Quote: stock wheels are not real beadlocks | |
10-10-2008, 01:28 PM | #9 |
hey what are some good shocks and beadlocks that arent too expensive that i can run??
10-10-2008, 02:51 PM | #10 | |
As for shocks most are using the 3Racing MLST alloy shocks or their Minizilla shocks. | |
