Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: lower cg
Old 10-11-2008, 01:11 PM   #1
Default lower cg
how to lower the cg and lower the ride hight??????????
redjeeper is offline   Reply With Quote
Old 10-11-2008, 01:15 PM   #2
CLA
From looking through these forums, it seems like everyone is putting the battery on the front upper link. Makes sense because it puts the battery much lower. If the battery is moved to the upper link, does the plug still reach the plug for the ESC in it's stock location??
CLA is offline   Reply With Quote
Old 10-11-2008, 01:18 PM   #3
Lower the height by moving your shocks to the chassis not the plastic top plate
hpirs4 is offline   Reply With Quote
Old 10-11-2008, 02:00 PM   #4
My battery is on my front upper links and my esc is on the rear axel and all the plugs reach.....
parker88 is offline   Reply With Quote
Old 10-13-2008, 10:23 PM   #5
droop. and mount electronics as low as possible.
wyocrawler is offline   Reply With Quote
Old 10-13-2008, 11:08 PM   #6
Lower CG:
• wheel weights
• move battery to front axle
• move ESC to front upper links
• move receiver to rear upper links
Lower ride height:
• use a droop suspension OR
• replace shocks with shorter ones OR
• disassemble shocks, insert a nylon spacer or plastic tube around the shock shaft INSIDE the shock, reassemble shocks.
XPLORx4 is offline   Reply With Quote
