10-11-2008, 10:57 AM | #1 |
Quarry Creeper Join Date: Mar 2008 Location: richmond
| axial wheel offset
whats the standard offset for the scorpian?
10-11-2008, 04:43 PM | #2 |
thanks for all the info guys! |
10-11-2008, 04:52 PM | #3 |
Did you look at all? Most are running the second option. 1st Offset - .443 (11.25mm) this is a negative offset, meaning that the bottom of the hex is as close to the hub side as possible. (see diagram) This offset offers a wider track width. (see photos below) 2nd Offset – Our latest design - This offset is .3325 (8.4mm) this is also a negative offset. This offset will bring your wheels closer to the frame, this offers a narrower track width of approximately 10 ¼”. (see photos below) |
