section525 | 10-14-2008 12:33 PM | Quote:
Originally Posted by 2JSC
(Post 1381633)
| I'm looking for an alternate method for lengthening the links instead of using the spacers and longer bolts. I re-drilled my stock chassis to use the 70mm post as uppers. But once I four link it, I don't really want to have a spacer at the bottom of each link. Unless I have to. :-( Quote:
Originally Posted by MystRacing
(Post 1382067)
I've looked around quite a bit and it looks to me like you need to buy round rod and drill it to make your own links. The problem is the tubing is typically around .035" wall thickness which is to thin to practically thread. Schedule 40 aluminum pipe has twice the wall thickness at .07 inches but starts at an OD of .41" so it's really too big. That's about all I could find becides solid rod. Just for reference you can't beat www.onlinmetals.com if you need a little metal stock. They don't have minimums so if you want a 2" long piece of 1/4" tubing they'll be happy to sell it to you. | You're right. This tubing is difficult to find. Solid rod may be the way to go. I just don't have a mill to drill it out with, and I can't imagine being successful using my hand drill or drill press. :shock: Is that what people are doing though?
Optimally, I would like to find something with an ID just smaller than .09843" so I could tap for the stock M3 Axial rods. But I'd settle for the .1065 Stampede rods as well. But everything I've found in that range has an ID of .125". :???: Too small.
I'll keep plugging along. Thanks guys. "thumbsup" |
