10-23-2008, 03:56 PM | #1 |
Newbie Join Date: Oct 2008 Location: omaha
| flex issue
if i use the front right to crawl up something it flexes as it should but if i try to the left it lifts the right tire up also. almost like if i put torque on that side the chassis leans to the left. i no this sounds funny but it is hard to explain. any help would be nice
10-23-2008, 04:41 PM | #2 |
Rock Crawler Join Date: Sep 2008 Location: Mid Mo.
run a search on torque twist should tell you what you need to know
10-23-2008, 04:43 PM | #3 |
Quarry Creeper Join Date: Feb 2006 Location: Surrey B.C Canada
Any chance you could post a vid clip? Or even some body off shots top & bottom of your rig All I can think of is if you made your own rear drive shaft it might be to long like:You glue a cut down male into the female shaft and then install a female on the other side..If one female touches the other under flex it could efect twist I ran into this on my old rig playing with driveshaft lengths....the other is make sure the 2front and the 2rear upper links are the same lenght as each other rear to rear front to front not front to rear cause that wouldn't effect anything to do with a articulation prob. like this..Or anything hitting an upper link...Chassis screw But I don't know I'm just fishing in the dark here |
10-23-2008, 04:43 PM | #4 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
my friend your crawler is infected with a bad case of torque twist |
10-23-2008, 05:23 PM | #5 |
Quarry Creeper Join Date: Jul 2008 Location: Galt
Yup, that's torque twist. The easiest and cheapest way to combat it is to try to put more weight onto the front right part of the axle and to put thicker shock oil in the left rear and front right shocks. Preloading the left rear and front right springs also helps, with more preload on the left rear. Ultimately you may need to use a 4-link suspension setup.
10-23-2008, 06:24 PM | #6 |
i have 4 link and i will do some more research. thanks for the help.
