12-09-2008, 10:43 PM | #1 |
Newbie Join Date: Dec 2008 Location: graham wa
| 3rd channel
i have a losi mrc that i put rear steer on. my buddy has a 3 channel transmitter and reciever off one of his old cars (traxxas if that matters). other than losing my spectrum capabilities, would this be a simple plug and play to gain a third channel or am i over looking something. thanks. Blake Last edited by slowgo; 12-09-2008 at 10:49 PM. |
12-10-2008, 08:02 AM | #2 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
plug and play
12-10-2008, 01:47 PM | #3 |
Rock Crawler Join Date: Mar 2008 Location: ...in your meter box...
Yep, that will work. If you were planning on full time 4 wheel steer, you could just use a y-harness and plug both servos into it. That way you dont have to lose the spekktrum or change your Tx or Rx. |
12-10-2008, 06:41 PM | #4 |
would i just ignore the batt. terminal on the traxxas receiver. the batt on my mrc goes into the ESC.
12-11-2008, 09:55 AM | #5 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
The third chanel on a stock traxxas transmitter is a one position switch, so when you flip the switch it would just move the servo in one direction, so if you rear wheels were straight and you flipped the switch it would only turn the rear wheels to the right or left but not both dirctions from the center position, also you would not be able to control how far the wheels turn, it would be all or nothing and only in one direction other then straight, not proportional like the front steering is. Tom's Y harness idea would be the better route as long as you don't mind having full time 4WS, but if you plan to do any comps 4WS is only allowed in the Super class and not in the Mini 1.9, or 2.2 classes.
12-11-2008, 10:34 AM | #6 | |
Newbie Join Date: Aug 2007 Location: Long Grove, IA
12-11-2008, 04:42 PM | #7 |
There is an extensive thread on this in the electronics section. Here is the wiring diagram. There are two ways to rig up the switch, the top pic shows the remove having the stock two-position thumb switch and a three position switch, with a another switch to select between the two. The bottom pic is the wiring for just the three-position switch. Hope this helps. The mod is easy, it takes about 30 minutes and about $15 at Radio Shack. |
