12-12-2008, 12:36 PM | #1 |
Rock Crawler Join Date: Dec 2008 Location: Over at yo mama's house
| noobie ?'s hey guys, i've read some of the threads already but still un sure on a few things. i hope these are not stupid ?'s. thay don't seem bad to me. 1. does it matter if i put my reciever on the steering servo? 2. how much weight can you put in the tires without messing with the flex of the tire?(can you stack multiple lines of weight on top of each other?) i have 4oz. in each right now. it helps but still not enough. 3. what about running smaller foam in the tires? i know about cutting the foam but how about smaller foam? 4. can enyone give me a good link to building a small indoor course. i have seen most of the stuff already on the site, just wanting to gat some ideas. thanks in advance to all who help. just getting into it and i am already hooked. i have an axial ax10 artr, rooster crawler combo with 55t motor. just put new body on just to keep it different from others. any advice for a newbie would be greatly appreciated. the site rocks!!! keep it up. cavie98 |
12-12-2008, 05:20 PM | #2 |
Rock Crawler Join Date: Mar 2008 Location: ...in your meter box...
1. I dont think so...I know you should keep it far away as possible from motor. 2.What do you mean flex? more weight! 3.Yes. 4.Artificial Rock Course I hope this helps. |
12-12-2008, 09:00 PM | #3 |
Pebble Pounder Join Date: Oct 2008 Location: Fresno
Don't get to caught up with weight. Yes you will need to add SOME weight to your wheels.... but you also need to LOWER the center of gravity. Once your able to climb decent inclines without it wanting to flip over backwards you are in the ballpark with your weight and your center of gravity. Just remember the more weight you add the more traction your going to need to pull all that weight UP an incline. LCG more important than weight.... always
