01-03-2009, 10:23 PM | #1 |
Pebble Pounder Join Date: Feb 2008 Location: here
| Brushless Gearing and power questions
I recently bought a Sidewinder and 5700kV motor package to put in my crawler I just built. The crawler has AX10 axles and transmission. The pinion I am running is 18 tooth and the spur gear is an 87 tooth. I am using a 1200mAh 6 cell NiMH. I am new to the whole programming of the ESC so based on what I have read here I set the brake to 100%, drag brake to 100%, punch to 0%, Start Power high, Motor timing to 15. the rest is default. When I start to crawl the truck stutters. It has plenty of wheel speed but seems to have little torque. Based on what I have written here what are some possible solutions? Is the motor too much for the system? What about the spur or pinion. I have an AX10 basically stock running a Rooster Crawler ESC and a 65T motor. It doesn't have speed but it has LOTS of torque. What can I do so my new truck also has lots of torque using a brushless setup? |
01-04-2009, 10:47 AM | #2 |
Rock Crawler Join Date: Nov 2008 Location: lakeside
you need to get a low kv motor. the motor you have is made to go fast.
01-04-2009, 11:20 AM | #3 |
Quarry Creeper Join Date: Jun 2008 Location: Hell
I've seen some people use that type of motor (5700kv) what they might have been using is something that stops them cogging and stuttering, I don't remember what it's called.
01-04-2009, 11:40 AM | #4 |
Can I use a sensored motor with the Sidewinder ESC? I was thinking of using a Novak SS4300. |
01-04-2009, 01:08 PM | #5 |
Quarry Creeper Join Date: Jul 2005 Location: pleasant ridge
a smaller pinion and larger spur will give you more torq. and lessen the coging.
01-04-2009, 01:53 PM | #6 |
Quarry Creeper Join Date: Feb 2008 Location: chico
ive heard u can use sensored motors with sensoreless escs but ud still have cogging u defonitly need smaller pinion gear and a bigger spur if u can get one to fit. lower kv towood b good holmes hobbies makes a 1000kv motor i think they call it a revolver or crawlmaster has a seald can,ooh yea and its sensoreless to perfect for the sidewinder or mambamax, and not to pricey
01-04-2009, 01:59 PM | #7 |
the sidewinder is sensoreless i had the same prob i got the mamba max ps if u get a big servo invest in the cc bec its like $25 er less cause the internal bec on you esc might not like it much and itll keep yer esc cooler the cc bec is castle link capable u can make shure ur servo is getting 6v |
