Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Cc bec ???
Old 01-05-2009, 03:54 PM   #1
Default Cc bec ???
I have seen these little blue units labled "CC BEC" 10 amp peak.
I see they limit the voltage. They say up to 25V in and 6 to 9V out. Where is this wired in, and why would you need one??
Thanks,
LR
Little Rhody is offline   Reply With Quote
Old 01-05-2009, 04:34 PM   #2
you wire it into your servo. it gives power to your servo so you dont have to run a servo pack. if u need more info try searching
4ONDFLR is offline   Reply With Quote
Old 01-06-2009, 03:01 AM   #3
Yeah there was some threads in the electronics section, maybe it was a sticky, but it had great pics and diagrams.
Ryan33 is offline   Reply With Quote
Old 01-06-2009, 07:50 AM   #4
Yah, I posted this in the electronics section, but the moderators moved it to the newbee section.
LR
Old 01-06-2009, 06:56 PM   #5
On the lookout for Rocks
constantmotion's Avatar
LR
They moved it to the Newbie section b/c you would have got flamed pretty hard in the Electronics section....this is question and has been answered many times.
A Battery Eliminator Circuit (BEC) is a little device that eliminates the need for a receiver and servo battery pack. It draws higher voltage from the motor batteries and drops it to a voltage level that is suitable for your receiver and servos. This is required in applications which draw high power for multiple servos or use more than 3S motor packs, as most ESCs with linear BECs are not designed to deliver enough V to power the high torque servo.
You wire it directly in to your ESC's battery connector and then plug it into your receiver. Yes, you do need one....to be able to turn those wheels when crawling.
Check this video out. JRH at Holmes Hobbies deminstates the power of the BEC
http://www.youtube.com/watch?v=32SNV...&cat=13&page=1
constantmotion is offline   Reply With Quote
Old 01-06-2009, 09:12 PM   #6
Ok, I think I understand this.
But I have a 3cell lipo, do I still need one? Also I am running the new JR super high torque 403 in oz, and the Novak goat 18.5 turn brushless motor and esc combo. Wont my 3 cell lipo, provide 12.6 volts to my servo via my receiver? or will the receiver drop the voltage??
If I dot run one, will I burn anything up, or will I just not have enough power at the servo??
Thanks for your help.
LR
Old 01-07-2009, 12:18 AM   #7
K_B
The ESC regulates the voltage; not the receiver. The battery plugs into the ESC and the ESC plugs into the receiver and supplies around 5 or 6V of power. The receiver then feeds the power to the servo. If you ran 12.6V straight into a receiver, it would blow up or at the very least, it wouldn't run for very long before blowing up.
If you don't run the external BEC, you won't burn anything up, you just won't have enough juice, like you said, because the BEC circuit built into the ESC can't supply the amperage needed for those high torque servos.
K_B is offline   Reply With Quote
Old 01-07-2009, 01:36 PM   #8
Ok,
So I need one. The wiring looks simple enough.
I just ordered one on line.
Thanks
LR
