02-01-2009, 01:52 PM | #1 |
Pebble Pounder Join Date: Dec 2007 Location: Dothan
| Better in Reverse.
see if someone can figure this one out. i went to place to do sone crawling and there was a pile of crushed rock and gravel. looked like fun so i started to do some crawling. i noticed that some of the places i tried to crawl while going foreward it would not make it through but if i turned around and tried it in reverse it would go right up. it also goes faster in reverse. WHY? thx Dirby. |
02-01-2009, 01:55 PM | #2 |
Quarry Creeper Join Date: Feb 2008 Location: New Rochelle
Flips your wires on the motor or change it on your radio. Reverse the throttle. You could have more clearance in the rear depending on you linkage. It also depends how you set up your battery and weighted your truck. picture or a better explanation would help us to help you.
02-01-2009, 02:33 PM | #3 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
Change the motor wires... then reset your esc to your radio.... |
02-01-2009, 02:57 PM | #4 |
Quarry Creeper Join Date: Apr 2007 Location: Northern PA where the rocks grow wild
Reverse your motor wires.... black to red and red to black...... That is why you are goin faster in reverse than forward. You might have to reverse the throttle switch on your radio to keep your current settings. Quick easy fix..... |
02-01-2009, 04:44 PM | #5 |
Pebble Pounder Join Date: Jan 2009 Location: Crestview
check the EPA-(end point adjustment) on your radio. i will adjust mine for better control on wet rocks.
02-01-2009, 09:19 PM | #6 |
RCC Addict Join Date: Jan 2004 Location: Gunbarrel
It also may depend on what motor you have. If it has adjustable timing it may not be set at zero. If the motor has advanced timing and you flipped the trans, like many do in the MRC this is more then likely your problem.
02-01-2009, 09:46 PM | #7 | |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Just turn the body around. | |
02-02-2009, 07:58 PM | #8 | |
Pebble Pounder Join Date: Dec 2008 Location: MIDDLE TN.
JEFF | |
02-02-2009, 08:03 PM | #9 |
02-02-2009, 08:15 PM | #10 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
wires shmires... i'm all for quick and easy. flip the body around. |
02-02-2009, 11:23 PM | #11 |
Pebble Pounder Join Date: Jan 2008 Location: E. Concord
make sure you have your endpoints set on your radio correctly when you reset your speedo to your radio
02-03-2009, 12:12 PM | #12 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
i have this problem w/ the stock 27t motor in the AX10 RTR. its WAY too fast to crwal forward, as it just jumps and jerks w/ the lightest trigger pull. i reversed my wires and such, and its a big improvement. @least until i get a 55t this weekend |
