Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: average 2.2 dimensions
Old 02-14-2009, 12:13 AM   #1
Default average 2.2 dimensions
hello,
I'm gonna build a crawler and gonna use 2.2 size tires, I am also going to make my own 2 plate chassis, my question is what are the most common sizes? Length/width/height(depending on suspension setup)
Thanks
Flag
Flagbmx is offline   Reply With Quote
Old 02-14-2009, 08:29 AM   #2
are you talking chassis size or overall truck size? there are maximums for each class (1.9/2.2/super) posted, so if you wanted to compete you would have to be within those limits. However that is only for over all size, the chassis can be as big or as small as you want (unless its a tuber)
nj05nismo is offline   Reply With Quote
Old 02-14-2009, 01:33 PM   #3
I was wondering from wheel to wheel(max), so that way I can get an idea of how to make the chassis
Thanx man
flag
Old 02-14-2009, 01:37 PM   #4
Thanx man
flag
for a 2.2 comp rig maximum wheelbase is 12.5"...center to center of axles...max track width is also 12.5" outside to outside of tires....most comp rigs run about the max wheel base and probably between 9.5 to 10.5 width
http://www.usrcca.com/rules2008.pdf
...if your not gonna run comps,you can pretty much do whatever you want
TIMZKRAWLER is offline   Reply With Quote
Old 02-14-2009, 11:09 PM   #5
AH SWEEEET!! thanks, saved that to my computer , also another question is, i am going to build my chassis out of "I THINK" it's 1/8 inch steel plate, might even do diamond plate for extra "BLING" LOL, what are some ways to do this? and whats a good BUDGET tranny? under 40
you guys are helping me alot
Thanks
Flag
Old 02-15-2009, 07:04 AM   #6
the steel plate will be way to heavy. there is a reason most people use aluminum/delrin/cf. You want as light of a chassis as you can have.
as for tranny - i vote axial.
Old 02-15-2009, 12:20 PM   #7
Really? i thought that you'd want more weight towards the bottom? to lower the CG?? but imma newb, what do i know? , and i did some reading last night, and i think im gonna run to wal-mart for some cutting boards , Also i was looking at the axial tranny, i think i'mm gonna go with that.. ESPECIALLY FOR 30.00 bucks. I was gonna use my Monster GT tranny but it has WAY to much slop and the whole reverse deal is dumb. So i can get around 50.00 for that and have some extra cha-ching
Thanks ALOT Guys
Flag
