02-15-2009, 08:01 AM | #1 |
Newbie Join Date: Jan 2009 Location: fritch
| axle
i have the ax10 artr and this is the second time i bent a axle. is there a stronger one out there or is there a way to stop this? thanks
02-15-2009, 09:48 AM | #2 |
Rock Crawler Join Date: Mar 2008 Location: ...in your meter box...
What do you mean by "bent"? Are you talking about the inner shaft or the plastic housing? Pics?
02-15-2009, 02:36 PM | #3 |
Newbie Join Date: Oct 2008 Location: Northbay
I don't think you can bend the axial housing or axles but I could be wrong there is some after market axles for the front and rear I think most of the shops on here carry them.
02-15-2009, 07:21 PM | #4 |
sorry the inner shift
02-16-2009, 07:41 AM | #5 |
Quarry Creeper Join Date: Sep 2008 Location: Kuala Lumpur, Malaysia
If it's soft enough to bend without breaking while you are driving, it's probably soft enough to straighten and use again? I think I saw someone else post here that he did that. Just an idea. Cheers. |
02-16-2009, 11:12 AM | #6 |
I have never had an issue with my Axial axles shafts.....still my original shafts and I have put it in some bad binds.
02-16-2009, 01:35 PM | #7 |
I have personaly never had a problem either but after searching around I see some other guys have had this issue also, mostly after taking a tumble. Here is a link to some stainless steel ones. Hope it will help. http://www.teamstrc.com/ebproductdet...inid=15&id=242 |
02-16-2009, 06:58 PM | #8 |
thanks for the post. guess time to upgrade now
