02-17-2009, 11:09 AM | #1 |
Newbie Join Date: Feb 2009 Location: Gardiner
| AX10 only turns one direction?
Sometimes when using my AX10 RTR the tires will only point in one direction and will not not turn in the other direction. Its very frustrating Ive tried tightening the screws on the front axle but it never stays straight. Ive had it since Christmas so its only been through snow if thats what messes it up. Anyone know what causes this and how to fix it?
02-17-2009, 11:17 AM | #2 |
You are talking about steering direction and not tire rotation, right? It sound like the plastic servo horn is stripped, pull it off and take a look at it, you'll likely see all of the teeth gone, or laid down in one direction. This is an easy fix, I recommend getting an aluminum servo horn. When you take the servo horn off, turn the TX and truck on, turn the servo from left to right using the TX to make sure you actually have full travel, next, do the same thing again, but hold the servo output shaft just hard enough to put backpressure on the servo, make sure that it turns like it is supposed to. Last edited by Greatscott; 02-19-2009 at 08:01 AM. |
02-17-2009, 11:35 AM | #3 | |
02-17-2009, 11:43 AM | #4 | |
02-17-2009, 11:44 AM | #5 |
02-17-2009, 01:08 PM | #6 |
Cool, glad to help, just make sure that you test the servo out as well, but if the horn is stripped then it is likely working... Happy Crawling! |
