02-20-2009, 11:40 PM | #1 |
Quarry Creeper Join Date: Dec 2007 Location: Blue Jay
| Binding issues..
Ok, so I got a rooster crawler from Bowtie here... I wired it up, then turned on the radio, pushed the "set" button, and then turned on the esc. I got a flash of green and red lights, then it went to solid red. At that point, I pulled the trigger full throttle on the radio (like the novak instructions say) and waited for the light to turn green. I waited a solid 3 minutes and it never turned green. Am I just not waiting long enough, or am I having an issue with the esc or radio? I know, its a newb question, but I've been searching all night and haven't found anything on it. Scott |
02-20-2009, 11:47 PM | #2 |
RCC Addict Join Date: Nov 2007 Location: BV
Sometimes ESC's won't calibrate unless your throttle is reversed. Or it's already reversed and it doesn't like that. Check in to it. Also, most ESC's I've used make you hold full throttle before you turn the ESC on. It's been a long time since I calibrated a rooster, so I don't know about that one. Something else to try anyway. |
02-20-2009, 11:49 PM | #3 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Your steering servo work?
02-20-2009, 11:51 PM | #4 | |
Ultimate RC Decals Join Date: Aug 2005 Location: San Antonio
02-20-2009, 11:55 PM | #5 |
RCC Addict Join Date: Jan 2009 Location: ?????
i too just had that issue last night. how do you have it plugged into the receiver? the black wire should be towards the outside of the receiver. do you have control of your steering?
02-21-2009, 12:12 AM | #6 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
To program rooster. http://www.teamnovak.com/download/in...r_crawler2.pdf |
02-21-2009, 12:14 AM | #7 |
I don't have steering or throttle... I will check to make sure that the reciever is plugged in there correctly... Scott |
02-21-2009, 12:46 AM | #8 |
yea, i was getting frustrated with it too so i called novak (great tech support by the way ) and all i had to do was flip it plug it in and then do the programming again and it worked fine....
02-21-2009, 01:01 AM | #9 |
Rock Crawler Join Date: Oct 2008 Location: San Bernardino Mountains
If you need help bring it by tomorrow & we will get it working. I also have a spare new rooster that we can compare & test with.
02-21-2009, 08:18 AM | #10 |
Quarry Creeper Join Date: Apr 2008 Location: Fondy, WI
i was gonna say, binding the rooster is a million times easier than the mamba max.... |
02-21-2009, 09:11 AM | #11 |
Got it figured out fellas.. had a few issues, like throttle and steering were going the opposite ways than they should, but I reprogrammed and flipped one of my channels on the radio, and its working great. Now to buy some velcro to stick it all to the chassis... I can already tell this rooster is going to work 100 times better than that puny associated xps micro that was on it when I got it. Scott |
02-21-2009, 09:37 AM | #12 |
sweet, what kind of crawler did you get? just surious :-?
02-21-2009, 10:53 AM | #13 |
I ended up with a wheely king with a 4 link.... I am enjoying it although I am modifying it tosuit my tastes as I can. Scott |
02-25-2009, 12:00 AM | #14 |
Rock Stacker Join Date: Jan 2009 Location: Bay Area
check your connections in the receiver to make sure they are correct as the esc won't like it. 10 seconds is probably a long time to wait
02-25-2009, 06:55 AM | #15 |
I have run across multiple ESCs from Novak that had incorrect calibration instructions in the manual. You might want give them a call for some help.
