03-05-2009, 04:52 PM | #1 |
Newbie Join Date: Apr 2008 Location: PHOENIX
| best motor
what is the best motor for a super thanks jeff |
03-05-2009, 05:05 PM | #2 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
Being a little more specific on what Super you're putting it may help? But, is there really a "best" It's a very subjective question. I would bet you're going to get a different answer from every poster. |
03-05-2009, 05:43 PM | #3 |
| ok
thanks well my truck is a g-made stealth and is the g-40 or g-50 good for my crawler u think and also what do u think would be good from ur opinion thanks jeff |
03-05-2009, 05:46 PM | #4 |
My advice would be to talk to Johnrobholmes from Holmeshobbies, a vendor here on the forum. He'll set you up with some very good options. |
03-05-2009, 05:47 PM | #5 |
| thanks
thanks
03-05-2009, 05:48 PM | #6 |
what kind of crawling will you do? Fun, or competing? A brushed motor is your most inexpensive solution, but "best" is very subjective. If money is no object then two sensored systems would have high power and zero maintenence. Two sensorless systems would have light weight and high power at a lower cost, but low speed control would suffer.
03-05-2009, 05:50 PM | #7 |
well im thinking about comps but i got to set up my crawler first so right now just messing around with it thanks for ur help jeff |
03-05-2009, 05:53 PM | #8 |
For a budget to get you going, two 55t motors from Integy, Novak, or Tekin would be a great start. If you are looking for higher performance you can look for a Handwound brushed motor from JP Customs or myself. I think a brushed motor would be the best place to start so you don't spend hundreds and hundreds on a dual motor setup.
03-05-2009, 06:24 PM | #9 |
| ok
thanks i have been rock crawling for a little if that changes ur mind on the motor u think u want me to get but thanks for the advise
03-05-2009, 06:27 PM | #10 |
well i just figured out that im using the 55t motors from Integy and i think i need something better thanks jeff |
03-06-2009, 09:25 AM | #11 |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
I run 35t motors in my Clod based super and would not have it any other way. |
