03-13-2009, 06:33 AM | #1 |
Rock Stacker Join Date: Mar 2009 Location: Ontario
| Which traxxas big-bores?
I've decided to go with traxxas big-bores for my suspension. However, I've noticed there are two versions. I'm trying to figure out which one to use. There is the big-bore (part #2660) and the xx-long big-bore (part #2662). I'm not quite sure which is the correct one. |
03-13-2009, 08:19 AM | #2 |
Pebble Pounder Join Date: May 2008 Location: Tyler, Texas
One has the janky steel shock shafts, and one has gold colored nitrate coted shafts. go for the goldish ones, they are much stronger
03-13-2009, 08:27 AM | #3 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
03-13-2009, 09:10 AM | #4 |
Thanks rockpiledriver. Can you recommend which springs and oil weight to use? I definiately like those and the price too!
03-13-2009, 09:21 AM | #5 |
Rock Crawler Join Date: Apr 2008 Location: Highlands Ranch, Co.
| You can use Losi springs, most use the white's & 30-70 wt oil, testing will determine what weight oil is best for you. (Not Rockpiledriver but thought i would answer & help you out.)
03-13-2009, 09:43 AM | #6 |
Thanks speedracer19. Most of the threads i've read seem to suggest using losi white springs with traxxas bb's. Your right about testing oil weights. I'll just experiment with different viscosities until i find a set-up that works for me. Cheers.
06-20-2009, 09:57 AM | #7 |
Quarry Creeper Join Date: Nov 2008 Location: Slovakia
i saw some setups without springs do they use heavier oil or there is internal spring? |
