| | #1 |
| Newbie Join Date: Mar 2009 Location: southwest
| i searched the forum and didnt find anything just wandering if you had a no price limit to spend on a ax10 can you build or is there an ax10 that can beat a berg or the new losi crawler that will be coming out? |
| Sponsored Links | |
| | #2 |
| Back in the WATER! ![]() Join Date: Mar 2008 Location: Pacific Ocean
| The rigs do not drive themselves. With that said a Berg suits me better and I feel I am a better driver with a Berg as opposed to an AX-10. Others will say the opposite. The dig operation alone makes a Berg a better decision for comps IMO. The Losi still is not out yet. You can build a Berg for less than a comp AX10 with after market chassis and built axles. |
| | #3 |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| Sure. A Berg can beat an Ax-10 as well as a Losi can beat a Berg as well as a Losi can beat an Axial as well as a Berg can beat a Losi as well as an Axial can beat a Losi as well as a .... Set up and driver wins. |
| | #4 |
| im curios cause i wanted to build a ax10 with the dual motor setup like the berg im new to this stuff so not sure what that setup is called of course it comes down to the driver but i was aiming my ? towards spec wise |
| | #5 |
| Spec wise they all will need to follow the 2.2 class specs....found in the rules forum towards the bottom of the main page. Basically comes down to a shafty (Axial,Losi or the likes) or a Berg. Any of them can be competitive with the right set up and a good nut behind the wheel. |
| | #6 |
| Gold Star Baby! ![]() Join Date: Mar 2007 Location: Kerman, Ca
| The AX-10 uses one motor only. And its called MOA(motor on axle) You need axles like Bergs, HR, Bully's for a MOA rig. |
| | #7 |
| | #8 |
| RCC Addict Join Date: Jan 2009 Location: Crawlifornia
| not sure who makes them, but I know I have seen a complete axial artr running MOA axles on it. |
| | #9 |
| RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
| I drive an $800-$900 Berg and I get beat by AX-10's all the time... A good rig that performs well helps, but it's good driving and experiance that wins comps. |
| | #10 |
| Hot Racing make's them, they're basically Berg copies that are a bit narrower, you have to run a bunch or Berg parts in them to keep them from breaking though.. lol |
| | #11 |
| Pebble Pounder Join Date: Mar 2008 Location: columbus
| Once you buy the HR moa axles you can hardly call it a ax10. sure you can use the chassis from an ax but it will be like most other trucks a hybrid of some sort. I would suggest buying the Berg axles over the HR if for no other reason beyond PROOVEN reliability. HR axles are still quite new and few vendors will have parts when you need them. Berg, on the other hand has been around for a while by one name or another and guys love em for a reason. There are also 3rd party upgrades to be found on the forums where you will find next to none fore the HR's Just my thoughts |
| | #12 |
| | #13 |
| Pebble Pounder Join Date: Apr 2008 Location: Hong Kong
| I've been hearing this stuff FOREVER... and it's all BULL$HIT Think about it like this... if I were to compete against a paraplegic (no offense intended) who trains 24/7 in a single sport... chances are I will lose. Why.. simply put, the paraplegic spent more time mastering the art... This is the same CRAP people repeat here... setup/driver... for crying outloud if a seasoned pro whos practiced for ages on a shafty beats a MOA. THIS DOES NOT MEAN the shafty is competitive or practical. When you are on the rocks, you will notice that precise movement is key... hence the lower speeds as well. When in this situation, HOW will a shafty that consistantly lifts a leg compete with a fully planted MOA??? |
| | #14 | |
| Pebble Pounder Join Date: Nov 2007 Location: Houston
Get a rig that you will be happy with, not what everyone else tells you that you should get. Then learn how to use what you got to your advantage, find its strong points and then find its weak points and improve on them. Not every rig will work for every driver. That is the fun in this hobby because its all up to how you want it to drive. You can however listen to what everyone else tells you to get but where is the fun and pride in that? If someone asks you why you choose to run product A on your rig and you cant come up with another answer other then I was told to use it. Instead of, Oh I choose this product because it functions this way and and that way and it works for how I am using it. Then well...there is no pride in your rig. Everyone wants the best thing but there is no best thing. Every product will work differently between every person. | |
| | #15 |
| Rock Crawler Join Date: Jan 2007 Location: Secret Crawl Location Deep In England
| | #16 |
| Pebble Pounder Join Date: Dec 2008 Location: Cen Cal
| Good Posting!!! I like my Venom. |
| | #17 |
| Rock Crawler Join Date: Sep 2008 Location: N.E. Mpls
| berg vs shafty the monthly arguement find a better topic or reread the old ones... |
| | #18 | |
| RCC Addict Join Date: Nov 2008 Location: Urbana,MaryLand
Sounds like some one just dosn't know how to set up a shafty so they went and jump on the Berg bandwagon. Shafty's are for real men. | |
| | #19 | |
Daily Guy who feels he needs to make some one new feel dumd. Get over your self & just don't click on these dumd threads. It's not like you didn't know were this was going when you saw the title. | |
| | #20 |
| Pebble Pounder ![]() Join Date: Feb 2006 Location: Farmington
| i beat bergs in our comps with no dig. Driving skill in my opinion is 95% and 5 % rig. Its is different for everyone. I am building a MOA just for the dig set up. Will see if i like it or not. Good luck |
| Thread Tools | |
| Display Modes | |
