05-06-2009, 09:20 AM | #1 |
Newbie Join Date: May 2009 Location: Hueytown
| Motor confusion
need somebody to explain 55t 45t 35t in enlish what does that mean and which is the best for crawling competitivly!
05-06-2009, 09:41 AM | #2 |
45T means that the wires are wrapped around the armature 45 times. In general, the lower the number of winds, the more speed you get and the lower the torque. The higher the number of winds, results in higher torque and lower speed. As for which is best, well, you'll need to give some specifics about the rest of your setup. 45T will be a good starting point... |
05-06-2009, 09:48 AM | #3 |
Rock Crawler Join Date: Feb 2009 Location: Sale Creek, TN
| The higher the number the slower it goes. The 35t will give you more wheel speed. The 55t is good, but I have had alot of guys wanting the 45t and 35t the most, and they run in the comps around here. |
05-06-2009, 10:21 AM | #4 |
Im wanting to go with Aixal Ax 10 or Crawler venum and run Novac esc and bigest baddest battery i can find thats not Lipo! any battery suggestions would be a help also! thanks for the replys so quickly!
