View Poll Results: To brush or not to brush | |||
Brushed Tekin FXR | 7 | 50.00% | |
Brushed Something else | 5 | 35.71% | |
Brushless LRP Crawler | 2 | 14.29% | |
Brushless Sidewinder | 0 | 0% | |
Voters: 14. You may not vote on this poll |
05-24-2009, 12:15 PM | #1 |
Rock Stacker Join Date: May 2009 Location: San Francisco
| To brush or not to Brush that is the question
been doing some searching for ESCs, debating what to get, brushed setup or brushless. I've been told the brushless does not have the low end torque needed to be a comp set up, but if it turns the wheels, it works. On the other end, I've seen the "power" of the brushless system. What do to??
05-24-2009, 12:27 PM | #2 |
Pebble Pounder Join Date: Apr 2008 Location: Indiana
Brushed Tekin FXR. They are the most adjustable and provide the smoothest throttle response especially on the low end. Unless your competing against me.....then you want something else |
05-24-2009, 12:57 PM | #3 |
hahaha, I really want to try the LRP crawler, I've always had good to say about the LRP, my 6 on roads have LRP speed controls, but this is completely new
05-24-2009, 08:43 PM | #4 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
Brushed hands down...you can always alter your power with battery choice and/or gearing. Brushless is getting better, but in my opinion you'll never get one as smooth down low for crawling. If you're really on the fence, pick up a Castle Sidewinder (which will handle both) along with a Castle BEC and Link, and a nice brushed motor. Drive it, tune it, tweak it...and if you end up wanting brushless, you're all set to make the switch with the Sidewinder |
05-24-2009, 09:54 PM | #5 |
is the sidewinder the same like the goat, they can go brush or brushless??
05-24-2009, 10:07 PM | #6 |
It is...but I personaly stay away from the Orange...I just don't think that the quality is there any longer.
05-24-2009, 10:35 PM | #7 | |
RCC Addict Join Date: Nov 2007 Location: BV
Personally I think the Mamba Max is the best setup. I've never had a sidewinder, but I have a couple FX-Rs and they can't touch the smoothness of a Mamba down low. Not to trash talk the FX-R, I'm quite happy with them, the Mamba is just so damn smooth I can't imagine anything ever touching it. I'd run that with a 35 or 45t motor, 3s lipo and a CC BEC (which you'll need with most anything) and you'll have a pretty sweet setup Edit: I've found a bit of expo does a good job of compensating for the FX-R's slightly twitchier bottom end. Once you do that you'll be hard pressed to tell a difference. Also, the Tekin ESC's I've used don't take well to cheap radios-most ESC's have some sort of filter for the noise that inevitably comes with cheap (27mhz AM stuff primarily) radios, the FX-R doesn't have this; it does exactly what it's told. I'd guess you have a decent radio if you have 6 on road cars though, it's just good to know about. Last edited by chrisjlittle; 05-24-2009 at 10:40 PM. | |
05-25-2009, 12:23 AM | #8 |
RCC Addict Join Date: Jan 2005 Location: Germany north
05-25-2009, 01:38 AM | #9 | |
I think I narrowed it down to either the Tekin FXR or the mamba Max brushed with some sort of motor. Last edited by Happy_trucker; 05-25-2009 at 01:40 AM. | |
05-25-2009, 01:55 AM | #10 |
Pebble Pounder Join Date: Feb 2005 Location: The Aloha State....Aurite!
Brushed Motors all the way.............because of the control and "smoothness" |
