05-28-2009, 06:08 PM | #1 |
Newbie Join Date: May 2009 Location: Phoenix
| Axial ax10 stutters/glitches when turning right....HELP!
I just bought a used Axial ax10 that I have been trying to fix and get going. It hesitates/stutters when I turn right at almost a pulsing rate. It sometimes also torques the steering straight while turning right. It consistently does this and I have seen it do it when turning left once. Here is the information on my truck: I currently have a Novak motor I just recently upgraded the following when the problem started: Installed a Thunder Power Lipo battery Installed Side Winder speed controller Bought a Futaba T3PM transmitter Any suggestions/ideas would be greatly appreciated! I am hoping to get this up and going so I can go play this weekend! Last edited by LexieVW; 05-28-2009 at 06:25 PM. |
05-28-2009, 07:04 PM | #2 |
Quarry Creeper Join Date: Apr 2009 Location: Ukiah
What steering servo are you running? You made need to look into getting a BEC. Do a search for more info on one.
05-28-2009, 07:40 PM | #3 |
I am running a JR ST126MG servo. I will take a look around and see what I come up with.
05-28-2009, 08:03 PM | #4 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
It obviously shouldnt be doing it noticably. You might check to see if your end points on your servo are set right. And above all, check to be sure the super smart person that installed the servo didnt run the servo all the way to on side before installing the servo arm on it. Pull the arm off, Turn the endpoints on your radio wide open, and run it left to right. once it hits far right (or left) make a mark at the top center of the servo arm gear. Then turn the steering on the radio back slowy until that mark is horizantal. This should be the center of the servo, and is where you need to install the servo going as straight down as possible. If that doesnt help, then disconnect the servo from the ESC and turn the front wheels by hand all the way to the right, and drive the rig in a circle. If that cures your problem you need a BEC. If that doesnt do the trick then the servo is bad. Good luck. Darryl |
05-28-2009, 08:06 PM | #5 |
RCC Addict Join Date: Sep 2007 Location: WHEAT RIDGE, CO
Prob need a BEC for that ESC....the sidewinders don't have nearly enough BEC power to run anything IMO... Hey i was the fat judge at the comp this weekend at Hobby town.... We'll fiqure this out for ya |
05-28-2009, 08:36 PM | #6 |
RCC Addict Join Date: Jul 2008 Location: San Diego
Are you running a 3 cell lipo? I think you need a Castle BEC also. I had to make the steering link longer to fix mine. The steeing link from the servo to the knuckle I made longer. I tried everything to fix it. Try the BEC first.
05-28-2009, 09:00 PM | #7 |
| I am running a 3 cell lipo. Sounds like you had a lot of problems! Did you try a BEC first as well and then have to do all of that as well? Thanks!
