06-01-2009, 03:10 PM | #1 |
Newbie Join Date: May 2004
| Losi Comp or AX10?
I'm looking to get a 1/10 scale crawler and right now I'm trying to decide between these two. I've been browsing the forum, and doing a bit of research and I've still got a few questions. First, is the worm-drive axle on the Losi as big a pain in the ass as it seems? Seems like it's creating way too much friction and heat in the axles and the motor. I'm not really looking to run BL, so that really is a big deal to me. The Axial axles seem pretty solid and a good design. Am I right? Also, how much better is the Losi's steering? I know it's got the CVD's and the Axial doesn't, but the Axial isn't really a schoolbus, is it? I'm most likely going to braze up a tuber chassis, so stock chassis doesn't really matter. Is the DIG setup a big pro? Sounds like it might be a weakpoint to me. Just looking for some reassurances so that I know I make the right decision. Thanks.
06-01-2009, 03:15 PM | #2 |
i went to my hobby shop and the losi just takes it compared to my ax-10 you wont haveto buy much at all for it to be comp ready
06-01-2009, 03:16 PM | #3 |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
The Losi is new and has bugs - If you buy one now you'll have to deal with them and be patient. The dig is pretty slick and the axles don't even roll a mm when engaged. The Axial is proven and has a huge aftermarket. You can buy the CVD's for it. If you must have something now, go axial ARTR or RTC, if you can wait till the bugs get worked out, go Losi. |
06-02-2009, 11:31 AM | #4 |
Quarry Creeper Join Date: Jan 2009 Location: Langley, BC, Canada
The worm gear axles on the Losi are IMO a far superior design. Having a rig that won't roll, unless it is powered, is sweet. As for extra heat and friction from the axles, I wouldn't say that it would be an issue. Worm gears are a very smooth, and efficient design. I have the AX10, and I will be buying a Losi when I can get my hands on one. Bugs or no bugs, I'd say it is a better rig. Yes the Axial is proven, and the aftermarket is huge, but give it time and the same aftermarket will be supplying for Losi. You just get better goods right out of the box with the Losi. You buy an Axial, and you are looking at quite a few bucks to get its components to the same level.
06-02-2009, 11:45 AM | #5 | ||
06-02-2009, 12:13 PM | #6 |
Wow hey. Don't I just feel like a total dipshit. Thanks Harley.
06-02-2009, 01:12 PM | #7 |
I just think that there is a lot of proving to be done before we can call Losi a good alternative to the AX10. I think that RTC is a great starter rig. Really wish it would have been around when I started even.
06-02-2009, 01:33 PM | #8 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
yup. The axial is a well proven design. I would go with it for that reason alone. |
06-02-2009, 01:33 PM | #9 |
Quarry Creeper Join Date: May 2006 Location: York Area
seems like their are no benefits to a Losi....Shocks leak, ( I know so do the axial's axials ), CVD's are weak, worm gear axles have too much friction, Tranny makes grinding noises if you tighten the slipper enough to climb something, the dig may be ok since nobody has complained about that yet but that may be because they haven't been able to run the Losi's long enough to encounter problems with them. Get the Axial ARTR ( with orange links and beadlock rings ) or the RTC it already has alot of the hop-ups, nice painted body and is a proven reliable crawler. Just add a dig of your choice and you will have a nice rig. But if you want to win comps the only thing you should be considering is MOA |
06-02-2009, 01:34 PM | #10 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
Go with the AX-10 especially if you ever plan to compete. As Harley said it remains to be seen if the Losi can even crawl a couch without breaking a CVD or losing pins from the drive line or bursting into flames:-P. I bought the Losi hoping it would be a viable alternative to my berg in certain situations....boy what a disappointment the losi is. It is still in the box on the bench next to my berg that kicks ass while I decide if I want run it. Long story short go with the AX-10 ARTR and drop a little coin to improve it as you can. |
06-02-2009, 01:40 PM | #11 |
06-02-2009, 01:53 PM | #12 |
06-02-2009, 02:11 PM | #13 | ||
RCC Addict Join Date: Jan 2005 Location: Germany north
3. and 4. Berg | ||
06-02-2009, 02:17 PM | #14 |
go with a used AX10 from the for sale section. I see comp setups that are just missing electronics all the time.
06-02-2009, 02:56 PM | #15 | |
Rock Crawler Join Date: Aug 2007 Location: Casper, WY
Helhedded hit it right on the nose. You're on the right track by doing research ahead of time. You can pick up really nice AX10's in the For Sale section all the time. Buying somebody else's project can save you a lot of $$. | |
06-02-2009, 03:00 PM | #16 |
hehe.. I didn't notice this guy was new to RCC with 6 posts. FYI, you have to have 30 tech section posts to see the For Sale section. Or you can buy a green star, which you will probably end up doing anyway if you get to enjoy the RCC.
06-02-2009, 06:05 PM | #17 |
Quote: Originally Posted by Crawlin4fun But if you want to win comps the only thing you should be considering is MOA Quote: Originally Posted by greasypete 2,2'' Modified 1.Egressor (44) 2.blickdicht (68 ) 3.bOAH (130) 4.mattin (150) 5.Mountymudder (159) 6.Psycodelic (169) 7.yaz (180) 8.Babu (184) 9.Uli (189) 10.Scooter (236) 11.Miata (281) 12.Andi S. (297) 13.stediju (361) 1. and 2. AX10 3. and 4. Berg Apparently Germans cant drive MOA Rigs..:mrgreen : |
