06-17-2009, 09:58 PM | #1 |
Rock Stacker Join Date: Jun 2009 Location: Canada
| Battery questions
HI, What does it mean when you see 2/3a in a battery description? Another question is, are you better off to run a smaller to mid mah pack like 1500 or will running a higher mah like 4600 affect anything adversely. Would a higher mah rating give longer run times? Just wondering if it is like rc heli's where you are dealing with motor heat issues with higher mah batts with longer run times. Thanks |
06-18-2009, 12:10 AM | #2 |
Quarry Creeper Join Date: Jan 2008 Location: Cyprus
2/3a is the physical size of the cell. These are the cells that are used for nitro car receiver packs. More mah = longer runtime. The only drawback to huge mah ratings is the size and weight of the cells and packs. |
06-18-2009, 10:42 AM | #3 |
Thanks |
