07-08-2009, 07:59 PM | #1 |
Newbie Join Date: May 2009 Location: San Diego
| going nowhere fast
So I just wired up my bully build, and when I powered it up to test my questionable wiring skills, everything worked, except that my motors are spinning in opposite directions. I wired them both pos to pos and neg to neg. should I just swap the polarity on the one going the wrong way?
07-08-2009, 08:02 PM | #2 |
Quarry Creeper Join Date: May 2009 Location: Chilliwack, B.C. Canada
you have to wire the rear motor up the opposite way for them to turn the wheels the same way.
07-08-2009, 08:06 PM | #3 |
that's what I figured, just wanted verification before I did it. Thanks bud! |
07-08-2009, 09:21 PM | #4 |
no problem |
07-09-2009, 12:44 AM | #5 |
Rock Stacker Join Date: Jun 2009 Location: cali
silly Q' but cant you just reverse the channel and make it run the other way? Does it run different fowards than backwards? My Ax10 was running backwards when I got it and I just reversed the channel, it has since been rectified but was that bad for it? |
07-09-2009, 12:57 AM | #6 |
problem is he has a moa rig, so 1 motor on each axle, if he reversed it using his transmitter then the rear motor still would not be turning the tires the same way as the fronts.
07-09-2009, 01:04 AM | #7 |
doh!!...lol I misread the question.
