07-09-2009, 10:03 AM | #1 |
Rock Crawler Join Date: Jan 2006 Location: Southwestern Pa.
| Battery mah question
I saw a post where someone purchased a Lipo that was marked 3S 1500mah, and they had it fail and disassembled it to learn it was actually only 1300mah. Well, I got two batteries from the same store, how do I tell what mah mine are?:?
07-09-2009, 10:18 AM | #2 |
What type of charger do you have? Some will tell you the input value...
07-09-2009, 10:58 AM | #3 |
Rock Stacker Join Date: Jun 2009 Location: cali
ya, run it down to the low voltage, plug it in and see how many mah's it takes. If your running lipo, you prolly have a decent charger.
07-09-2009, 11:56 AM | #4 |
I use a Hyperion 6060i I believe it is.....I have to select a mah setting prior to charging.:? I was setting at 1500 up until I read that post, and then tried 1300 to see what happened. It went to 1299 and ended. So it may just partially charged. Is there a way to tell by charge rate or something? |
07-09-2009, 12:21 PM | #5 | |
Quarry Creeper Join Date: Aug 2007 Location: Morrison Crawlerado
Which batteries are you referring to? I have two 1500mah CKRC 3S lipos. One holds about 1390mah and the other 1480mah. You kind of get what you pay for with cheap batteries unfortunately. | |
07-09-2009, 01:40 PM | #6 |
Quarry Creeper Join Date: Jun 2009 Location: Who's asking?
Do you have a volt meter? check the individual cell voltage; I would imagine that if the bats are not fully charging the voltage would not be reaching 4.2v/cell on a 1300mAh charge.
07-09-2009, 10:18 PM | #7 | |
