07-13-2009, 12:34 PM | #1 |
Newbie Join Date: Jul 2009 Location: lewistown
| building my first rig
my first rig is going to be a clod based 2.2 im making a torsion chassis out of aluminim u channel im going to be running integy 55t lathe motors, a tekin rebel2 esc, venom 3300mah battery, pro line masher2k m3 tires, and traxxas TQ2 radio does any body think this is a good first setup.
07-13-2009, 01:21 PM | #2 |
It's mostly going to be a matter of opinion. That looks like the specs from rigs of years past. Nowadays, guys are running 35T motors, Castle's Mamba Max or Sidewinder ESC, lipo batteries, HotBodies Rovers, Panther Cougars or Losi Comp Claws for tires, some sort of dig switch (either mechanical or electronic) and a chassis with some sort of actual suspension.
07-13-2009, 02:22 PM | #3 |
I think that this will be a great first crawler for you! I run a 2.2 Clod with a Pimp Cane chassis and it is an awesome setup for terrain that requires very high clearance. Here is my setup: Here's a video of this thing climbing some ledges: http://www.youtube.com/watch?v=ILsqOvwNhi8 I'd recommend that you get a 3 position switch for that TQ3 and setup either a DUD or PunkRC dig switch and your truck will be extremely competitive. As for the chassis, from what I have seen, the Pimp Cane flexes MUCH better than regular aluminum chassis... |
07-13-2009, 02:41 PM | #4 |
| first rig
thanks for your input and what wheel adapters do you use to put beadlocks on clod axles JeremyH how did you atach your chassis to the axles Last edited by customcrawlerX; 07-13-2009 at 02:43 PM. |
07-13-2009, 02:45 PM | #5 |
If I'm not mistaken, STOCK clod axles have a 12mm hex, so no adapter is required. But if you use CVDs, that's a different story (see below).
Last edited by K_B; 07-13-2009 at 02:56 PM. Reason: Edited to avoid confusion... |
07-13-2009, 02:47 PM | #6 |
I use heavily modified Losi Buggy 14mm hexes. The axles have cut down TTR CVDs and the hex pins fit them perfectly. I've also got small C tubes and the knuckles to fit them. Also, those are Mayhem beadlocks with (obviously) 14mm hexes with almost zero offset to help get the track width as narrow as possible. Also, the Pimp Cane chassis comes with mounting hardware. It uses a modified nylon bolt and nut that fit through the upper link mount. There is also a bracket that fits on the side of the chassis and on top of the gear cases. http://www.jpcustomrcs.com/PimpCane.html Last edited by JeremyH; 07-13-2009 at 02:49 PM. |
07-17-2009, 01:37 PM | #7 |
| rig
got my truck today striped down to the axles and are getting the difs locked and im going toget some proline sand paddle tires and mod the tread theyre really stickygoing to be awhile till i get my chassis done cuz i broke my wrist my truck is an original clod of ebay for 132.75 |
07-17-2009, 01:45 PM | #8 |
RCC Addict Join Date: Jul 2009 Location: Farmington, NM
Sucks about your wrist. Post some pics! Hope you get it up and going soon
07-24-2009, 10:27 PM | #9 |
| chassis
I got my chassis finished today the holes i drilled are not all strait for more flex i put my esc and tramsmitter on the chassis its going to be a super class i made the wheel base 18 inches im going to set up rear steer later i used the bullet tray part with all the holes from a cci 22 ammo box to mount my battery on the axle i get some pics up soon and if any body knows of some crawler courses in central PA/mifflincounty it be nice to know
07-25-2009, 12:36 PM | #10 |
| rc crawler
here is what i have done its not the neatest cuz i did it all with one hand the two tires in the bed of the body are mp3 speakers i reversed the tires till i get better tires i have a amplifier in the mp3 so you can hear it far away im going to add more speakers later and trim the body for more clearance who evar wants pics i will have to give me thier cell phone number my camera is not working i will pic message them to you |
