Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: loking in the left
Old 07-31-2009, 08:02 PM   #1
Question locking in the left
At any point I turn all the way to the left it binds the servo arm & gets locked up on the top how do I stop it from happening.
codeman is offline   Reply With Quote
Old 07-31-2009, 08:14 PM   #2
well you can either change your end points or get a longer servo horn
paintballer9876 is offline   Reply With Quote
Old 08-02-2009, 08:55 AM   #3
Take off the servo horn, and plug inthe battery to center the servo. Set your servo settings on your radio to ZERO, then re-attach the servbo arm. Now adjust the trim on the steering to give you the maximum travel both ways. You might have to do this with the EPA's. (End Point Adjustments) Hope that helps.
Krakker is offline   Reply With Quote
Old 08-02-2009, 07:29 PM   #4
The servo would still rotate as far and you would still have binding issues. Setting the servo with the radio to dead center and changing the endpoints are the things you can do.
tom tom is offline   Reply With Quote
