08-01-2009, 04:53 AM | #1 |
Newbie Join Date: Aug 2009 Location: MEXICO, ARIZONA
| Can I use Lipo's with any ESC?
I have like 20 Novaks. Mostly Dually's, Explorer's, 410-m5's, & Duster Sports. Can I use Lipo's with any of these ESC's? Or do I have to buy a Lipo capable ESC? Thanks, -Vince |
08-01-2009, 05:09 AM | #2 |
Rock Crawler Join Date: Feb 2008 Location: UK
Any ESC that works with a 6-cell NiMH or NiCad pack will work with a 2s LiPo. The nominal voltage is very slightly higher, but not enough to cause damage. In fact, a top quality NiMH will generally give more voltage than a 2s LiPo. The problem with using LiPos is that they really hate being run flat. By the time you notice the fall-off in power, it's often too late - the pack is damaged. this is especially true in a crawler, where you rarely pull a high current from the pack. Modern ESCs have a LiPo cutoff so the pack never runs too low. |
08-01-2009, 06:42 AM | #3 |
Newbie Join Date: Feb 2009 Location: Germantown
I use this from helidirect on my losi mrc. It works great and will keep you from runnning your lipo too low. Plus, it's really cheap. http://www.helidirect.com/iosc/produ...oducts_id=8158 |
08-01-2009, 07:50 AM | #4 | |
08-01-2009, 09:46 PM | #5 |
So do you recommend just sticking with nimh batteries. Unless I upgrade to a modern ESC? Capable of cutting the lipo off at a certain point.
08-01-2009, 09:54 PM | #6 |
Quarry Creeper Join Date: Mar 2008 Location: Zachary
08-02-2009, 12:00 AM | #7 | |
Newbie Join Date: Dec 2008 Location: Payson
08-02-2009, 12:10 AM | #8 |
Pebble Pounder Join Date: Jan 2009 Location: Planet Earth
a $25 dollar volt cutoff is all you need. Works will all Novaks, well, its made by Novak. Don't know why it doesn't work with the XL-5.... http://www3.towerhobbies.com/cgi-bin...?&I=LXPGM8&P=7 It has both the visual blinker, and a throttle disruption so you can tell when you drive. Quite nifty! |
08-02-2009, 04:48 AM | #9 |
Thanks for all the replies. So you're telling me I can run my Novak Dually with a 3s Lipo & a $25 cutoff switch & i'll be safe? |
08-02-2009, 06:06 AM | #10 |
The Novak Dually is only rated up to 7 cells, which is 8.4v nominal. A 3s LiPo is rated at 10.1v nominal, so it's likely to cause damage. Stick with a 2s LiPo and you'll be fine. |
08-02-2009, 10:22 AM | #11 |
| With all those ESC's, I would only run 2 cell lipos. They are all designed to run off stick batteries which go to 8.4V, and a 3 cell at 10V is going to zap fry them. Its like plugging a 120V tv into a 240V outlet.
08-03-2009, 06:22 AM | #12 |
08-03-2009, 06:40 AM | #13 |
Pebble Pounder Join Date: Feb 2009 Location: On the Rocks Dude....
08-03-2009, 08:17 AM | #14 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
08-03-2009, 09:06 AM | #15 |
Rock Crawler Join Date: Aug 2007 Location: Casper, WY
| The 410-m5's are rated 4-10cell Nimh (4.8-12.0v), you could run 3s with them, just be sure to use the correct cut-off and/or alarm as the others have stated. And don't forget, you need a Lipo capable CHARGER to go with them. Don't use any charger unless it specifically says Lipo compatable.
08-03-2009, 10:40 AM | #16 |
08-03-2009, 01:18 PM | #17 |
Oh wow! OK, so I can use my 410-m5's with a 3s. Cool perfect. My next question is. Will that 11.1v 3s lipo make the truck considerably faster? |
08-03-2009, 01:19 PM | #18 |
Thanks again for all the replies too. They're really helping me out. -Vince |
08-03-2009, 01:30 PM | #19 |
Quarry Creeper Join Date: Jul 2008 Location: peoria
hell yes just dont burnout the motor which are you using
08-05-2009, 02:18 AM | #20 |
