08-09-2009, 10:24 AM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: Alliance
| is there a.....
is there a good cheep 2.4 radio system with reverse!!! ???
08-09-2009, 10:26 AM | #2 |
Yes. The search button knows all...
08-09-2009, 10:29 AM | #3 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
Every radio has reverse. It's the ESC's that don't all have it. The racing ESC's do not have reverse but all of the general ones or crawling specific ones do.
08-09-2009, 10:50 AM | #4 |
08-09-2009, 11:06 AM | #5 |
I bought both my Spektrum radios in the classifieds here at RCCrawler. Less than $100 each. Keep an eye out.
08-09-2009, 01:34 PM | #6 |
Quarry Creeper Join Date: Apr 2009 Location: Ukiah
Just picked up the new ko propo from RPP hobby. 2.4ghz 3 channel 3 position comes with 2 RX $189.99
08-09-2009, 01:56 PM | #7 |
Rock Crawler Join Date: Dec 2007 Location: GILBERT
i would look for an old school DX3. they are the shiz after the toggle mod.
08-09-2009, 05:12 PM | #8 | |
| Quote: | |
08-09-2009, 05:21 PM | #9 |
RCC Addict Join Date: Nov 2005 Location: Kansas
08-09-2009, 05:57 PM | #10 |
08-09-2009, 06:59 PM | #11 |
Pebble Pounder Join Date: Jan 2009 Location: Planet Earth
| There are no hobby grade 2-channel stick radios that I know of that don't have a reverse or brake function. Its just the opposite charge of the axis for the throttle. You have a better chance finding a radio that can only turn right and doesn't come with right turn capability. Its the same thing. Its just two channels/axis and they both have a positive and a negative. If you wanted, you could make any hobby grade pistol radio steer with the throttle and do forward and reverse with the steering wheel. The only part that you need to watch out for when it comes to having reverse or not is the speed control. Top line racing ESC's do not have reverse on them for two reasons: you lower the resistance with less features, and its illigal to reverse during a race, because you reverse onto the track where people are still going forward and it just causes car breaking crashes. Just make sure your ESC has reverse. Here is my suggestion though. I have seen the inards of the RC4WD radio and its kinda sketchy, being an electrical engineer. It might look loads cheaper, but the inards are quality Futaba guts. http://www.towerhobbies.com/products/towj0224.html |
08-09-2009, 08:01 PM | #12 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
maybe he is thinking of reversing the servos...not steering to throttle..but from left/right to right/left????
08-09-2009, 08:33 PM | #13 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
If you are talking about a radio that will allow you to drive the vehicle in reverse, all hobby grade radios and recivers do. Its the ESC's that dont allow reversing. However if your wanting to know if the radio itself will allow reversing of the signal, then in that case, Almost all hobby grade radios will do so. |
08-09-2009, 10:23 PM | #14 |
so does it need a servo?
08-09-2009, 10:44 PM | #15 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
08-09-2009, 10:47 PM | #16 |
would this work http://www3.towerhobbies.com/cgi-bin...=LXLGF5**&P=TS |
08-09-2009, 10:48 PM | #17 |
i have one already bc i have a ax10 rtr
08-09-2009, 11:08 PM | #18 | |
Quarry Creeper Join Date: Dec 2007 Location: Flagstaff, AZ
08-09-2009, 11:12 PM | #19 | |
RCC Addict Join Date: Apr 2009 Location: United States of the Offended
This is the Hitec Laser 4 Four Channel FM Radio Control System with two HS-55 Micro Servos and Micro 05S Five Channel Receiver. Ideal for park flyer use. FEATURES: High quality precision gimbals with stick length and tension ATV (Adjustable Travel Volume) on Channels 1 and 2. ATV limits or extends the maximum throw of a servo Channels 2 and 4 V-Tail mixing option Trainer system-trainer cord not included, can use HRCM8310 Five LED battery indicators with low battery alarm One year warranty INCLUDES: One Hitec Laser 4 Four Channel Radio Control System with, Two HS-55 Sub Micro Servos One Micro 05S Five Channel Receiver One 9.6V 600mA Transmitter NiCd One CG-25A 110V Wall Charger (HRCP3025) One receiver crystal (HRCL23**), and one transmitter crystal One frequency flag set Two servo mounting hardware kits One antenna mount screwdriver Ilustrated instruction manual REQUIRES: Installing components into model and charging batteries. If ON/OFF switch harness is needed use (HRCM4407) SPECS: Transmitter, Operating System: Two stick, four channel Modulation: FM Power Requirement: 9.6V NiCd Micro 05S Receiver, Type: 5 channel, dual conversion 72MHz FM/PPM Power Requirement: 4.8V Nicd Size L 1.3" (37mm) x W 0.8" (20mm)x H 0.4" (10mm) Weight 0.3 ounce (8.6g) HS-55 Servos, Speed: 0.17 Sec at 60 degrees Output Torque: 15.27 oz-in (1.1 kg-cm) Weight: 0.27 oz (7.8 g) Length: 0.89" (22.8mm) Width: 0.45" (11.6mm) Height: 0.94" (24mm)COMMENTS: Differences between the Laser 4 and the Laser 6 Channel models: Laser 4 Laser 6 5 LED Battery Indicators Battery Meter ATV Channels 1 & 2 Dual Rates Channels 1 & 2 ATV on Channel 4 End Point Adjustment on Channel 3 jxs 11/07/05 ir/jxs __________________________________________________ _____________________________ It's not a surface radio and it doesn't look like it's available for surface use either and those servos that come with it are gonna be useless for steering a crawler. | |
08-09-2009, 11:14 PM | #20 |
