08-17-2009, 03:14 PM | #1 |
Rock Crawler Join Date: Feb 2007 Location: Lorain
| FXR Problems.
Figure I'll throw this up here since Im not sure if it should go in electronics or not. I've got a tekin fxr here that I picked up second hand. For some reason it seems as if the battery soldering pads(not the bar, the thing the bar is soldered to) has lifted and it will only work if you tap the esc. Is there any way to fix this? Like I said i picked it up second hand, and it seems that the red wire for the rx plug is completely removed, the switch is gone (no wires either). I'd like to either use it as a spare or sell it, but I'd like to know what I can do to fix it? Any way to get the pads back on the board? Hows Tekin's repair service as well? Thanks in advanced fella's. |
08-17-2009, 05:13 PM | #2 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
sounds like the previous owner got the solder posts too hot and the trace lifted from the board. If thats the case, then way too much heat has been applied to the esc and its probably toast inside too. Did the previous owner say it was in good working order? If so I'd contact the seller and see about getting your cash back.
08-17-2009, 06:36 PM | #3 |
Quarry Creeper Join Date: Dec 2008 Location: Aurora Colorado
Send it to Tekin and get it fixed. I do not think they charge very much.
08-17-2009, 06:56 PM | #4 | |
Thats what im thinking. Anyone got an estimate on the cost? I looked on the site but can't find shit. | |
08-17-2009, 09:59 PM | #5 |
Rock Crawler Join Date: May 2006 Location: Georgia
Send an e-mail to support@teamtekin.com. Good luck
08-17-2009, 11:37 PM | #6 |
Rock Crawler Join Date: Jan 2006 Location: Vacaville, CA
i've had nothing but positive experiences with tekin's service. I did get mad when i called and could not talk to a tech 'cause they were all out back working on there track LOL. But hey if i had that job i would be doing the same.
