08-24-2009, 03:07 PM | #1 |
Rock Stacker Join Date: Aug 2009 Location: Pasadena
| ESC Problem?
Hello All, Currently running a mamba Max with a Og revolver brushless setup. 14 tooth pinion and 87 tooth large spur, with a 7955tg servo. 3 cell lipo 11.1 V. When Im in tight spots and using a lot of servo steering, My ESC will cut out and start beeping, I have no throttle or steering. Until I pick up the crawler, once the pressure is off the servo the ESC begins working again. Should I get a BEC? Is the Mamba Max stock BEC cutting off becuase of the servo demmand? Any other clues why this might be happening? Thanks! |
08-24-2009, 05:28 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
You need a BEC. Your esc cant handle the load you are asking it to... |
