09-24-2009, 05:22 PM | #1 |
Rock Stacker Join Date: Apr 2009 Location: Trondheim
| Integy Heavy Duty Steel Gear Set?
just bought this set. just wondering if this SPUR is 48 Pitch like the stock one?
09-24-2009, 05:30 PM | #2 |
Rock Crawler Join Date: Jun 2009 Location: UK
Stock one from which truck?
09-25-2009, 01:13 PM | #3 |
sry. its for a AX 10
09-25-2009, 01:23 PM | #4 |
Quarry Creeper Join Date: Jul 2008 Location: Splendora
Yes it should be but I run the stock plastic spur on mine for a weak link in the drivetrain because I have the MIP steel driveshafts so the spur should strip before tranny gears go. Also my Integy spur was running out quite a bit it just wasn't machined very good.
09-25-2009, 04:08 PM | #5 | |
and I have noticed that i cant get the spur and pinion go smootly....? why is that exacly? makes much noise when i turn them and seems very hard to turn... wtf? Last edited by bjerk1; 09-25-2009 at 04:16 PM. | |
09-25-2009, 04:43 PM | #6 |
09-25-2009, 05:36 PM | #7 |
09-25-2009, 06:33 PM | #8 |
The plastic gears will survive fine. For running in the sand I would recommend switching to 32 pitch gears. The sand doesn't get stuck between the gears, causing them to strip, and they handle the power better. The Axial tranny in my Trophy Truck has 32 pitch gears with a CC4600 on 3S LiPo and I have no problems at all. Especially in the sand. To convert from 48 pitch to 32 pitch: ((48 pitch tooth count)/48 ) x 32 = 32 pitch tooth count For an 84 tooth, 48 pitch spur: 84/48 = 1.75 1.75 x 32 = 56 So you need a 56 tooth, 32 pitch gear to give you the same diameter of gear. For a 14 tooth, 48 pitch pinion do the same thing: 14/48 = .2916 .2916 x 32 = 9.3 So you need a 9 tooth, 32 pitch gear to give you the same diameter of gear. You can see that the gear reduction remains basically the same: 84/14 = 6 56/9 = 6.2 Last edited by Grizzly4x4; 09-25-2009 at 06:36 PM. |
09-27-2009, 07:00 AM | #9 | |
hmmm, okey. that seems cool and im gonna take that into consideration. but where can i get a spur with 32 pitch with 56 tooth who fits AX10 tranny? | |
09-29-2009, 09:32 AM | #10 |
Rock Stacker Join Date: Aug 2009 Location: Pasadena
