Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Quick Question, Please help??
Old 12-01-2005, 05:18 PM   #1
Default Quick Question, Please help??
I currently own x2 Kyosho Mag MAyhems and
was wondering if i could get away with using
an Emaxx ESC for this. I know i should be running
a SuperRooster for best rsesults but i can get my
hands on this Emaxx ESC for next to nothing.
I dont have the time to sit here for a length of
time and appologize if this questions been answered
10000x
Torredo.
Torredo is offline   Reply With Quote
Old 12-01-2005, 05:38 PM   #2
MODERATOR™
EeePee's Avatar
"Motors in series put the same load on the speed control as the total number of turns in both motors. For this set-up you can use motors with as few as 8 turns and the speed control will think its driving a 16 turn motor. You will get the speed and run times of a 16 turn motor with twice as much torque that is needed for heavier models."
Help any?
EeePee is offline   Reply With Quote
Old 12-01-2005, 05:58 PM   #3
06 Super National Champ
JasonInAugusta's Avatar
Connect one of each of the mayhems to the motor leads on the EVX. They're connected in parallel internally if I remember right.
The Mag Mayhems are 22 turn motors, should be fine on the EVX. Trinity makes lower wind motors for the E-Maxx.
Read the tech article that Twisted did on wiring the EVX for single battery use and do that.
Run a RX pack...the BEC portion of the EVX can't support 4WS.
JasonInAugusta is offline   Reply With Quote
Old 12-01-2005, 06:05 PM   #4
MODERATOR™
EeePee's Avatar
The EVX can do 11 turns?
Old 12-01-2005, 06:26 PM   #5
i knew you guys would help me out....Thanks a bunch~~
Appreciated!!!
Old 12-01-2005, 06:42 PM   #6
Check it out...
http://www2.towerhobbies.com/cgi-bin...?&I=LXWR57&P=7
The EVX will handle two of'm...the VX12 did as well, even though they say 19-27 turn motors.
The stock Maxx motors are 23 turn.
Old 12-01-2005, 06:56 PM   #7
The evx is 14.4v right? Will the mag mayhems handle 14.4v?
AdamF is offline   Reply With Quote
Old 12-01-2005, 07:07 PM   #8
Between all the bourbon and Coke I didn't think about that.
Wait...I did. Told him to do the single pack mod. ;)
Old 12-02-2005, 10:57 AM   #9
I would consider that max voltage for mag mayhems.
floogldood is offline   Reply With Quote
Old 12-02-2005, 12:00 PM   #10
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Help any?
I find that statement laughable and incorrect. Basically it states that you can keep your speed and runtimes constant and get 2x the torque for free. Torque is a constant of amp draw. hmm, something doesnt add up.
lets say going 10mph takes 100Watts 10 volts, 10 amps
When two motors are wired in series the voltage is split in half between the two (assuming they have = resistance), each motor sees 5 volts, and they draw amps independent of each other. This means they spin half speed since motor speed = voltage x kT.
If they are both fixed to the same spur, we can assume that the amp draw will be the same for both motors. Since the motors are spinning half speed the amp draw must double to 20 amps to keep the same power of 100 Watts. You will gear up to compensate for the slower motors. This is where the extra amp draw comes from.
I dont know who made that quote, but something has to give to get extra power. I explained this a long time back somewhere on this board.
JohnRobHolmes is offline   Reply With Quote
Old 12-02-2005, 12:29 PM   #11
Yes, the first two sentenses are a good general rule, but the last part of the last sentense is not correct unless explained a bit further.
Old 12-02-2005, 03:05 PM   #12
MODERATOR™
EeePee's Avatar
It's from here: http://www.tik.at/wdmotor.htm
Old 12-02-2005, 04:28 PM   #13
I agree. I shouldnt have quoted the entire passage. The third statment is just too ambiguously worded. It needs more details to be correct.
I have seen that quote somewhere else too. It seems that they are saying that two 8 turns will be like one 16 turn if they are wired in series, which I agree with. What he forgot to mention is that you will have to double your voltage and run two 6 cell (or enter your preference) packs in series so that each motor will still see full wattage. Add power, get power. It would be more efficient to use one powerful motor wound for high voltage instead of using two smaller motors, however.
Dang, am I spouting efficiency on crawlers in the Newbie section?
Old 12-02-2005, 04:34 PM   #14
MODERATOR™
EeePee's Avatar
Originally Posted by johnrobholmes
It seems that they are saying that two 8 turns will be like one 16 turn if they are wired in parallel, which I agree with.
Wired in series.
Old 12-02-2005, 04:36 PM   #15
MODERATOR™
EeePee's Avatar
And actually, I've used two 27 turn motors in series, and they do resemble the single 55 turn motor, but there is more power for sure.
Old 12-02-2005, 04:57 PM   #16
Wired in series.
thanks
Old 02-08-2006, 03:00 AM   #17
this whole series & parralel talk is the same as audio....
series = when x2 8ohm subs in series = 16ohms
parralel = when x2 8ohm subs in parralel = 4ohms
when wired in parralel will draw half the ohms meaning
a harder hitting bass line = more pull,
as when wired in series eases off and allows for
a cooler setup thus in this case = more runtime.
