10-08-2009, 06:53 PM | #1 |
Pebble Pounder Join Date: Dec 2006 Location: Southern Arkansas
| Dual ESC questions.
Planning a Bully rig. Will probably be running 45T brushed. I have 2 Mamba Max's at my disposal. Would there be any benefit to using both in this setup, or will a single one and a Punk dig switch work just as well? Also, if running dual ESC's, I'm assuming you're running 2 batteries as well? |
02-04-2010, 05:57 PM | #2 | |
Newbie Join Date: Jan 2010 Location: Monroe
I am ordering a bully rig and plan on running dual esc's with two 45t brushed motors. My question is, what would be the best esc's to buy and can I run two esc's off of one battery? I will be running this setup with a 4pk. also, will I need to run a bec with this setup? | |
02-04-2010, 06:09 PM | #3 |
You'll only need one battery, but make sure it's very high C rating. The BEC is gonna depend on what ESC's you run, with HH BR-XL's you can power the servo with one and the rx with the other, anything else and you'll need a BEC. I'd probably run BR-XL's and a high C 4s pack.
02-04-2010, 06:14 PM | #4 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
There advantage of duals is having a radio that will control them properly (4pk or sticks). Yes ya can run two esc off one battery.
02-04-2010, 10:19 PM | #5 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
I'm running dual Sidewinders in my Clod with a DX6i... Each is pushing a 35T Integy lathe motor.. I run a CC BEC on a much smaller 2S as well, so, there's no worries about which does what and all that.. I run a single pack.. A 2S 6200 LiPo... Both ESC's are set for auto cut-off and both will cut-off together when the pack gets down... Dual ESC's are, IMHO, the best way to go with a MOA rig... When Clod stall happens, you can kick a bit extra in the rear and off ya go... Et voila... No Clod stall...
02-05-2010, 01:51 PM | #6 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
I run dual Tekin FX-R's off one 1000 mAh 30c 3 cell battery with a CC BEC wired directly to one of the Tekin's. I use the Futaba 4pk as do most. You can just run a jumper between the two esc's so they share power from a single battery. You won't realize the full benefit of dual esc's without a 4ch radio like the Futaba 4pk or stick. Most run dual Tekin's because they are so small. Check out how Redneck21 wired his truck using dual FX-R's and one battery. Red's Rockshow Moonbuggy build... Last edited by Pdog7; 02-05-2010 at 01:58 PM. |
02-06-2010, 08:13 PM | #7 |
| This helps alot. thanks for the help guys. |
02-06-2010, 11:21 PM | #8 |
Pebble Pounder Join Date: Dec 2009 Location: KK Sabah North Borneo
sorry to hijack this thread.. but, i have almost the same question.. can the futaba 3PK be used with the dual esc combo??? or 4PK and the other stick radios only? thanks for any reply |
02-07-2010, 07:32 AM | #9 |
| The big problem with the 3pk and duals is ya can't have rear dig on the trigger and ya can't control front mix %. But yes ya can use the 3pk and duals. Front dig and rear mix % work great.
02-07-2010, 01:43 PM | #10 | |
i hope front dig n rear mix is good enough for the trail here ... OR just stick with 1 esc then. n just practice driving naturally more | |
