Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Motor & esc setup for the losi comp crawler
Old 10-26-2009, 04:19 PM   #1
Default Motor & esc setup for the losi comp crawler
Just wondering what would be a good combo for the Losi Comp Crawler? The goat 3s or something equal?
bberryuza is offline   Reply With Quote
Old 10-27-2009, 12:23 PM   #2
you should check out the Losi section, lots of talk about the Losi motor/esc combo. also check out http://forum.losi.com/forumdisplay.php?f=8 it's Losi's own forums for rock crawling.
I'm running an xcelorin 17.5 with an xcelorin esc. It's working very well so far. I just switched from a brushed motor that was hand-wound by a friend, and I had to be careful with it to prevent it from overheating (couldnt stay on it if I was bound up which was no good for comp settings when I needed to just power through things, and couldn't run the last 10-15% of my lipo, so I was getting drastically shortened run times). the brushed was working very well, but it was time for more wheelspeed, so stepped up to the brushless.
Del Montess is offline   Reply With Quote
