Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: tamiya high lift questions!
Old 10-27-2009, 10:58 PM   #1
Default tamiya high lift questions!
i was wondering if i could run a tamiya high lift with a spektrum dx 3.0 :?
shaw is offline   Reply With Quote
Old 10-28-2009, 07:13 AM   #2
Been there, done that
t_kirl's Avatar
You can, but you won't be able to use all 3 gears. You could set up the EPA's to use 1st and 3rd or 1st and 2nd or 2nd and 3rd. Basically, with the 2 position switch on the radio, you can only use 2 gears.
t_kirl is offline   Reply With Quote
Old 10-28-2009, 09:51 PM   #3
that wouldn't be bad or anything for it would it?
and also um... how would i be able to do that? lol
thanks
Old 10-28-2009, 10:04 PM   #4
Its not bad at all, i usually only use 1st and 3rd anyways. 3rd to get where im going, and 1st to climb the hillls!!
bad67dart is offline   Reply With Quote
Old 10-28-2009, 10:08 PM   #5
so... how do i program my controller to do that?
Old 10-28-2009, 10:13 PM   #6
You have to set your end points up on your controller so when the switch is one way, the servo is pushing the linkage all the way in for 3rd gear, and when you flip the switch, the servo pulls the linkage far enough back to pull it into 1st gear. It might take some tinkering with longer and shorter servo horns, but ill get it sooner or later.
