11-01-2009, 03:19 PM | #1 |
Newbie Join Date: Oct 2009 Location: crawlorado
| Cannot get the beads to stay seated???
Okay so i have reseated the beads on my new AX10 and they will not stay seated. It is really starting to irritate me. TIA
11-01-2009, 03:44 PM | #2 |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
I'm assuming you are meaning getting them to stay in place so you can put the beadlocks on, right? A big help is to cut your foams if you haven't already. I usually put a little spit on them to help them stick a little bit, too. |
11-01-2009, 04:07 PM | #3 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
put the tire on the rim and pull it right past the edge. put the bead lock rim and place and start all the screws just a few threads, pull the bead back up so its between the rim and ring, massaged the tire all the way around to make sure the beads in the groove. use the start pattern to tightin down the screws. do it in 2 or 3 passes so you dont just crank down one screw all the way right away. repeat the same steps for every bead
11-01-2009, 04:29 PM | #4 |
I have not trimmed the foams. Should i just cut them down a little? I am putting stick weights on the wheels soon so i can trim them.
11-01-2009, 04:35 PM | #5 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
what kind of tires?
11-01-2009, 05:33 PM | #6 |
Pebble Pounder Join Date: Sep 2008 Location: cny
they are a pain but practice makes perfect there is a thread under the ax10 section in the tips part that helped me out it's the 3rd or 4th thread in the section.once you get it right they'll all be cake.
11-01-2009, 06:28 PM | #7 |
Well after about an hour I finally figured it our and they are done. Got all the weights in but did not trim the foams
11-01-2009, 06:33 PM | #8 |
which ax10 do you have? the kit is the only one you wanna cut foams on (better off to just get decent tires with foams)
11-01-2009, 07:19 PM | #9 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
11-01-2009, 08:00 PM | #10 |
thanx ricky, thats a good idea. Why didnt i think of that?
11-02-2009, 06:13 PM | #11 |
