Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: can someone help
Old 11-04-2009, 07:15 PM   #1
Default can someone help
can someone explain the hole motor turn thing i know crawlers mostly run 45t and 55t but why and what a lower turn motor would be like crawling i'm new and learning so bear with me
spgrading is offline   Reply With Quote
Old 11-04-2009, 07:43 PM   #2
im pretty sure its because you dont really need speed you need more power
cody428 is offline   Reply With Quote
Old 11-04-2009, 07:43 PM   #3
From my understanding, higher turns = lower rpm, more torque, and uses less power. Lower turns = higher rpm, less torque, and uses more power.
Still kinda noob myself, so feel free to correct.
Paul208 is offline   Reply With Quote
Old 11-04-2009, 10:54 PM   #4
Lower turn:
longer run time
slower speed
less rpm
smoother throtle
For an ax10 i run a 35t for wheel speed and a 13tooth for the slower speeds.
ABOW is offline   Reply With Quote
Old 11-04-2009, 11:39 PM   #5
The higher the number of turns, the more torque the motor produces, but also the less all out wheel speed it can achieve. If you are wanting to simple crawl really slow on the rocks, go for a 55T. If you are wanting great all around abilities for all kinds of terrain, go with a 45T. I wouldn't go below a 35T motor for a crawler, and I would only recommend a 35T if you were going with a 3S LiPo. Otherwise get a 45T or a 55T.
BadRockNoCookie is offline   Reply With Quote
