Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: is this a stupid question???
Old 11-06-2009, 05:49 AM   #1
Default is this a stupid question???
am working on an ax-10 rig-not for comp but for bashin..moving the batts to the front axel,now am planning on getting this rig wet,should my batts be waterproofed??and how do i go about this???:?
mcreil41 is offline   Reply With Quote
Old 11-06-2009, 06:04 AM   #2
if you have a nicd or nimh batt your good to go but dont forget to water proof ALL other electronics
2500hdon37s is offline   Reply With Quote
Old 11-06-2009, 06:43 AM   #3
Nope, that's not a stupid question....
JeremyH is offline   Reply With Quote
Old 11-06-2009, 07:01 AM   #4
S ARR T 8's Avatar
There right I have a slash and belive me it is waterproof batts have been submerged many times and still going strong.But I am not sure about lipo ones I have not made that jump[yet].
S ARR T 8 is offline   Reply With Quote
Old 11-06-2009, 01:16 PM   #5
hahha, i have a hardcase lipo and my t4 fell into the pool and was submerjed for about 5 seconds n i unpluged it underwater b4 pulling it out n battery has been working fine since then...
yellowpasta2000 is offline   Reply With Quote
Old 11-06-2009, 04:11 PM   #6
maxamp lipo's are waterproof.
indiana mudcat is offline   Reply With Quote
Old 11-06-2009, 04:22 PM   #7
Who's your Daddy-0!
Not all of them are.
Even on your stick packs you need to dry them out after they get wet. If they get soaked like they do in our boats sometimes the batteries can get really hot and short out if they get to wet.
TattooKenny is offline   Reply With Quote
Old 11-06-2009, 08:25 PM   #8
To be sure, waterproof all your preciuos electronics and battery before going underwater. Always better to be safe than sorry.
CHRIZAD is offline   Reply With Quote
Old 11-06-2009, 11:49 PM   #9
fill your electronics up with dio-electric grease and you will be set to go swimming. i have done it to my bashers and i am still running the same esc for 2 years
jwalker is offline   Reply With Quote
Old 11-07-2009, 02:12 AM   #10
all lipo packs are water proof.
all lipo cells are sealed as they are made, as long as your pack is not puffed with a vented cell than you have nothing to worry about
Semi Pro is offline   Reply With Quote
Old 11-11-2009, 01:19 PM   #11
Default Not just electronics
Make sure you get the water out of the nooks and crannies.
Gearboxes can get water in them even though it doesn't seem possible. I don't know how it gets in there but I've had water inside of my Slash gearbox and differentials.
The change in the noise of the gears told me something needed attention. I'm pretty sure I reduced the life of some of my bearings.
davesnothere is offline   Reply With Quote
Old 11-11-2009, 01:42 PM   #12
Not so! Water won't get inside the cells, but that's true of most batteries. Water can cause the terminals to short out, which can cause a fire.
chrisjlittle is offline   Reply With Quote
Old 11-11-2009, 01:51 PM   #13
im with chris on this,,,my 2S lipos are waterproof as far as the individual cells are concerned but the wires that connect the cells together are exposed to water damage and corrosion etc....unless you have a pack listed as waterproof,,you better bag it or box it and make sure it is waterproof
rmdesignworks is offline   Reply With Quote
