11-14-2009, 03:01 PM | #1 |
Newbie Join Date: Jan 2009 Location: milton
| What is the best batterie to run in an axial ax10?
I am looking for a batterie that offers max crawl time
11-14-2009, 03:05 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
higher MAH = more run time, so whats your set up?? 3s lipo w/ 5000 mah u can crawl for days... 3s lipo w/1500mah can go for about 40-45 min
11-14-2009, 03:06 PM | #3 |
I'm trying to stay away from lipo
11-14-2009, 04:00 PM | #4 |
Newbie Join Date: Nov 2009 Location: Norway
is this the same if its a NiCd or NiMH? 1500mah = about 45min?
11-14-2009, 04:08 PM | #5 |
depends on your set up, but i seem to get longer run times with my 1500mah lipo and 35t then i did when i ran a 55t and 2000mah stick pack...
11-14-2009, 04:26 PM | #6 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
There even better when you spell baterie, battery!
11-14-2009, 04:44 PM | #7 |
Rock Crawler Join Date: Apr 2009 Location: Great Falls
It depends on your setup, on my ax10, I run a 1500 split pack 8 cell (2/3A). I get good run times and keep my center of gravity low. On my wifes scx10, she runs a 3300 7 cell (SC). Her run times are more than double of mine. Check out www.cheapbatterypacks.com for some info.
11-14-2009, 04:51 PM | #8 |
45t lathe and split pack 8 cell 1500mha one a ax10
11-14-2009, 05:37 PM | #9 |
Can you run an 8 cell on a axial ax10 rtr.
11-14-2009, 05:54 PM | #10 |
the stock esc is good for up to 10 cells. I'm running 8 cells on a rooster crawler without any issues.
11-14-2009, 06:32 PM | #11 |
does voltage matter
11-14-2009, 10:40 PM | #12 |
The batts are 1.2 volts per cell. 8 cell=9.6 vollts, 7 cell=8.4 volts etc.
11-14-2009, 10:52 PM | #13 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
I'm with big78...well just down the road...I run a 7 Cell 3300 mah and we get what....3 hours running around time??? I'm going to try my lipos tomorrow and see what I get. |
11-14-2009, 11:03 PM | #14 |
Where are your batteries mounted? The stock batt plate puts them to high and makes your rig top heavy. I have my batts on the front axle with homemade mounting plates. If you want more info let me know.
11-15-2009, 07:36 AM | #15 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
Man if you're gonna buy a batt don't waste your money on a nimh. Gp Lipo! |
11-15-2009, 08:23 AM | #16 |
can an ax10 handle 9.6 volts. What do you have to do to switch over to lipo. Im running my batteries an the front axle.
11-15-2009, 09:01 AM | #17 |
Rock Stacker Join Date: Oct 2009 Location: santa cruz,mtns.
What u need is a good lipo/ballencer combo charger. I run a triton eq for all my batt. . I run 1350 size 2s lipo on my crawler and i get about an hr with a goat system with the 18.5 motor. Lipos are the way to go. I fought buying but when i did couldnt believe the diference. |
11-15-2009, 09:34 AM | #18 |
11-15-2009, 04:14 PM | #19 |
don't lipos EXPLODE |
11-15-2009, 04:25 PM | #20 |
lol, Yeah they explode but so does NiMH if you dont take care of them correctly. Its a common thing that scares off people from using Lipo's. Follow the rules to handle and take crae of them and if you purchase good batteries by a reputable company, then youll have nothing to worry about.
