Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Pricing out Ax10 RTC's
Old 11-16-2009, 02:41 PM   #1
Default Pricing out Ax10 RTC's
Found some locally for $299.99 which is great since shipping is rediculous up here. Looks like it does not come with a battery (7.2V) or a charger though. I have no idea how any of the electronics work on these so not really sure what batteries to buy. I guess lipo is the best but will this rig work with a lipo out-of-the-box or does it need modification? I'm in no real hurry to build a competition rig right now so a basic setup that I can play around with is fine for now. Eventually I want to upgrade and make it a scaler.
rebel GMC is offline   Reply With Quote
Old 11-16-2009, 02:56 PM   #2
if i was you because your more of a noob id get some saddle packs like this
http://www.tcscrawlers.com/TCS-Crawl...r-p-16948.html
and a cheaper charger like this
http://www.tcscrawlers.com/DuraTrax-...0-p-17261.html
the saddle pack batterys will mount right on front axle improving preformance
2500hdon37s is offline   Reply With Quote
Old 11-16-2009, 02:58 PM   #3
Thanks for the info, those would work just fine. What kind of run time would those give me?
Old 11-16-2009, 07:05 PM   #4
It depends on the turns of the motor and electronics. When i was using those packs on an novak rooster with a 55t I was getting about 30 minutes of run time. Welcome to the addiction also.
firekiddc02 is offline   Reply With Quote
Old 11-16-2009, 07:53 PM   #5
My RTC was $258 at my Local shop,I got a new 6 cell 7.2 3800 mAh battery $35 and a Prophet charger $40 which brought me to $350 OTD. I have way more than that into it now
With the 3800mAh battery and the 55 Turn motor I can run around two and a half-ish hours. I havent gone Lipo yet but im looking in to it, but just starting out the NiMH battery works good even mounted in the high position on the chassis. I also recommend a good set of Deans connectors, their only about $4 per set.
BLKXJ 96 is offline   Reply With Quote
Old 11-16-2009, 08:26 PM   #6
The stock esc will work wit 2cell lipos if ya add lipo cutoff (easy). What ever ya do make sure the charger ya get will work with lipos.The price difference is so small there is no reason to not start off with lipos. It will cost ya more later not to!
oldhippie is offline   Reply With Quote
Old 11-16-2009, 08:50 PM   #7
Any place better than the other to purchase these? Seems kind of limited up here in the Arctic. More than likely I will have to get all this online.
Old 11-16-2009, 08:50 PM   #8
On ebay I found one for $249.99 shipped. You live in Alaska right?
THE CRAWLER KING is offline   Reply With Quote
Old 11-16-2009, 08:56 PM   #9
Yup sure do.
Old 11-16-2009, 11:57 PM   #10
And don't forget to get a Lipo BAG for charging the battery if you go with the Lipo!
03libertysport is offline   Reply With Quote
Old 11-17-2009, 03:01 AM   #11
GO Check out TCScrawlers... They rock and right now they have their Axial AX10 RTC for $237.00
http://www.tcscrawlers.com/Promotion...1-p-17397.html
you're welcome
also like said above.. Deans plugs are great and are needed if you go lipo as the plug on a lip is not the same as the truck end.. so you have to solder in the new plugs.. But I have 2- 2cell lipos and they are great.. i can crawl around for a couple hours with one, no problem!
311WJ is offline   Reply With Quote
Old 11-17-2009, 07:21 AM   #12
This would be my choice to go lipo with the stock esc;
http://www.allerc.com/product_info.p...oducts_id=3701
http://www.allerc.com/product_info.p...oducts_id=4647
http://www3.towerhobbies.com/cgi-bin...P?I=LXPGM8&P=8
Old 11-17-2009, 12:58 PM   #13
Check local ads also. I picked up a AX10 RTC on craigslist.com for $160. It was 3 weeks old. Came with everything but the charger. It was some racer dork that didnt like crawling.
chevrock is offline   Reply With Quote
